Update Icinga(web) for PHP7.4 to PHP8.1 upgrade
I have a debian system with
  • Icinga Web 2 Version 2.11.4
  • PHP-Version 7.4.33
I want to install “GitHub - Mikesch-mp/icingaweb2-module-grafana: Grafana module for Icinga Web 2 (supports InfluxDB & Graphite)”, but this requires PHP8.1 and greater.
I installed PHP8.0 and PHP8.1, but icingaweb won’t work with PHP8.x.
I set the apache modules for each version seperatly and i globally set the PHP-Version in Debian (with update-alternatives …).
I don’t use php-fpm.
What have i to do that icingaweb2 works with PHP8.1?
Thanks for help.
We are having the same issue :frowning:
@theFeu What’s the real status about icingaweb2 and php8.x ? Can’t find anything relevant anywhere…
I forwarded this topic to our devs :slight_smile:
Icinga Web, libraries and modules all support PHP from version 7.2 up to 8.1 currently.
What’s the actual issue you have? Errors of any kind?
Ohhhhh got it. PHP8.2 is not supported, we just downgrade 8.2 to 8.1 and it’s working.
Sorry for my delayed answer.
My problem was that i installed PHP8.1 but apparently not the necessery moduls.
After i have installed it, icingaweb2 works.
So for me the Problem is solved.
