Unmet dependencies found! Module can't be enabled unless all dependencies are met
I would like to activate the Nagvis module, but I have a problem. Here is the error message I have on Icinga web:
While on my Icinga server, I have the following information:
~# icingacli module list
MODULE VERSION STATE DESCRIPTION
director 1.11.3 enabled Director - Config tool for Icinga 2
idoreports 0.10.0 enabled Reports for IDO
incubator 0.22.0 enabled Incubator provides bleeding-edge libraries
monitoring 2.11.3 enabled Icinga monitoring module
nagvis 1.1.1 enabled NagVis integration
pdfexport 0.10.2 enabled PDF Export via Google Chrome/Chromium
reactbundle 0.9.0 enabled ReactPHP-based 3rd party libraries
reporting 0.10.0 enabled Reporting
Here is some additional information about my Icinga:
~# icingacli version
Icinga Web 2 2.11.3
Git Commit f917436a894c1f4148a9c3d6a27f9c20f204e44f
PHP Version 7.4.33
MODULE VERSION
director 1.11.3
idoreports 0.10.0
incubator 0.22.0
monitoring 2.11.3
nagvis 1.1.1
pdfexport 0.10.2
reactbundle 0.9.0
reporting 0.10.0
I am on Debian 12
Thank you in advance for your help. Feel free to ask if you need any additional information.
there is a problem in the module.info in this release:
you can replace the depends line with this:
Depends: monitoring (>=2.0.0)
or try the master branch of this module, if there are still issues with the newer versions of monitoring or icingaweb2
Thank you, I no longer have the error message, now i can enable the module correctly. However, I still have a problem: when I click on maps in the menu, the display duplicates, whereas I should normally see the map that is in my files on my Icinga server.
did you try the master?
the release is like 7 years old.
I just did it, but I still have the same problem. The only thing that has changed is that I now have a menu that opens.
I think you have some strange apache2/nginx redirecting config in place.
the url that the nagvis module is trying to reach is:
/nagvis/frontend/nagvis-js/index.php?mod=Map&act=view&show=demo-overview&header_menu=0
can’t do more for you since I do not use nagvis
