Undefined variable, and i don't know why
This is what i am trying to do from icinga console :
<6> => node = "lubshvh52"
null
<7> => schedule = "hv_dm_chv09_wawssql12"
null
<8> => get_services(node).filter((sv) => match("*" + schedule, sv.name))
<8>: get_services(node).filter((sv) => match("*" + schedule, sv.name))
Error while evaluating expression: Tried to access undefined script variable 'schedule'
<9> => node
"lubshvh52"
<10> => schedule
<11> =>
Replacing schedule with static string works, but i’d like to use a variable. What am i doing wrong here?
You might need to import the variable into the function scope:
function() use(that) { ... }
Though, I don’t know how to apply this to the arrow syntax.
You can use the variable just as Johannes suggested for the arrow syntax as well.
<8> => get_services(node).filter((sv) use(schedule) => match("*" + schedule, sv.name))
