Unable to schedule SLA reporting via Icingaweb2 reporting interface
I’ve just finished adding reporting to my Icinga2 installation. Works well - even manually triggering an email to send the report as a PDF attachment works a treat.
I’m now trying to schedule the SLA reports to be sent out at the beginning of every month but was unable to save the form. It returned the General error below when I clicked the Create Schedule button. I searched for this specific error via Google, Github, and the forums here to no avail.
Anyone else seen this and was able to resolve?
SQLSTATE[HY000]: General error: 1364 Field 'start' doesn't have a default value
  • Icinga Web 2 version: 2.11.4
Used modules and their versions (System - About)
Loaded Libraries
icinga/icinga-php-library 	0.12.0
icinga/icinga-php-thirdparty 	0.11.0
Loaded Modules
idoreports 		0.10.1 	Configure
monitoring 		2.11.4 	Configure
pdfexport 		0.10.2 	Configure
reporting 		0.10.0 	Configure
Copyright © 2013-2023 Icinga GmbH
  • Web browser used: Firefox 115.0.2
Icinga 2 version used (`icinga2 --version`)
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.0-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Ubuntu
  Platform version: 22.04.2 LTS (Jammy Jellyfish)
  Kernel: Linux
  Kernel version: 5.19.0-1029-aws
  Architecture: x86_64
Build information:
  Compiler: GNU 11.3.0
  OpenSSL version: OpenSSL 3.0.2 15 Mar 2022
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
PHP version used (`php --version`)
PHP 8.1.2-1ubuntu2.13 (cli) (built: Jun 28 2023 14:01:49) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.2, Copyright (c) Zend Technologies
    with Zend OPcache v8.1.2-1ubuntu2.13, Copyright (c), by Zend Technologies
  • Server operating system and version: Ubuntu 22.04.2 LTS
EDIT: Defaulting to closed details
Interestingly, I restarted the old server - Icinga v2.9.3 - and there I’m able to save the schedule and after running the schedule I found the report in my inbox.
So, it looks like the latest version has broken something
Icinga2 v2.9.3 server details
Loaded Libraries
icinga/icinga-php-thirdparty  0.10.0
icinga/icinga-php-library  0.6.1
Loaded Modules
grafana 	1.3.6
idoreports 	0.9.1
monitoring 	2.9.3
pdfexport 	0.9.1
reporting 	0.9.2
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.1-1)
System information:
  Platform: Ubuntu
  Platform version: 20.04.6 LTS (Focal Fossa)
  Kernel: Linux
  Kernel version: 5.4.0-155-generic
Build information:
  Compiler: GNU 8.4.0
  Build host: runner-hh8q3bz2-project-508-concurrent-0
  OpenSSL version: OpenSSL 1.1.1f  31 Mar 2020
General paths:
Internal paths:
# php --version
PHP 7.4.3-4ubuntu2.19 (cli) (built: Jun 27 2023 15:49:59) ( NTS )
Zend Engine v3.4.0, Copyright (c) Zend Technologies
    with Zend OPcache v7.4.3-4ubuntu2.19, Copyright (c), by Zend Technologies
The latest version you’re talking about is the default branch of the repository. This isn’t a release and as such you’re using it at your own risk. There’s probably a database upgrade necessary, but mind you, don’t apply it if you’re not in the mood to revert it once the next release is out.
Thanks for the feedback, @nilmerg
I see where I went wrong now but at the time, it all seemed to work correctly as I was seeing the expected version numbers. I’ve now checked out tag v0.10.0 which works as expected. I did not have to change anything else - i.e. pdfexport and idoreports are both on the default branch as cloned. Since it is working fine at the moment, I’ll leave them as is.
ak.
