Unable to load object referenced from service "", failed to load icinga_command
I have new installed:
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.3-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: Debian GNU/Linux
Platform version: 10 (buster)
Kernel: Linux
Kernel version: 4.19.0-16-amd64
Architecture: x86_64
Build information:
Compiler: GNU 8.3.0
Build host: anubis
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Director: master
reactbundle: 0.7.0
incubator. 0.6.0
ipl: v0.4.0
Now if I want to configure at Director a host template at “Check-Command” I get the error
“Unable to load object referenced from host “generic-host”, failed to load icinga_command “host” (IcingaObject.php:539)” during type “host…” instead of the possibilities.
The same error at service templates. Additional here I can’t choose several imports, because the popup doesn’t run.
Do you have some ideas, what there goes wrong?
Greetings
Andy
Hey Andy,
you are using a quite old version of icinga - it’s over 2 years old. It is recommended to use the official repos: Index of /debian
As you just installed Icinga I would recommend starting form scratch using the official version.
Kind regards
Hello Nexo1960,
really? I don’t believe it. I have 2 Icinga2 installed and both comes from
cat /etc/apt/sources.list.d/icinga.list
deb-src Index of /debian icinga-buster main
and has these installed packages:
dpkg -l | grep icinga
ii icinga2 2.10.3-2+deb10u1 amd64 host and network monitoring system
ii icinga2-bin 2.10.3-2+deb10u1 amd64 host and network monitoring system - daemon
ii icinga2-common 2.10.3-2+deb10u1 all host and network monitoring system - common files
ii icinga2-doc 2.10.3-2+deb10u1 all host and network monitoring system - documentation
ii icinga2-ido-mysql 2.10.3-2+deb10u1 amd64 host and network monitoring system - MySQL support
ii icingacli 2.6.2-3+deb10u1 all simple CLI tool for Icingaweb2 and its modules
ii icingaweb2 2.6.2-3+deb10u1 all simple and responsive web interface for Icinga
ii icingaweb2-common 2.6.2-3+deb10u1 all simple and responsive web interface for Icinga - common files
ii icingaweb2-module-doc 2.6.2-3+deb10u1 all simple and responsive web interface for Icinga - documentation module
ii icingaweb2-module-monitoring 2.6.2-3+deb10u1 all simple and responsive web interface for Icinga - monitoring module
ii php-icinga 2.6.2-3+deb10u1 all PHP library to communicate with and use Icinga
ii vim-icinga2 2.10.3-2+deb10u1 all syntax highlighting for Icinga 2 config files in VIM
The first of the both doesn’t this described problem, only the second installed.
Best regardy
Andy
The latest version of Icinga is 2.12.3:
I am not sure why you have such an old version, as Debian Buster is officially supported.
But this doesn’t explain the error on the second icinga2 server. I don’t believe your arguments, that’s another reason. Especially when the first with same packages runs well.
After a night, suddenly tomorrow it is running well. The commands and imports will be shown in pulldown lists.
I don’t known the reasons for this behavior.
Second point of @nexo1960 of suggested link to the Icinga repository for Debian Linux
https://icinga.com/docs/icinga-2/latest/doc/02-installation/
I expect to find there latest stable running Icinga version not the same as the official Debian repository.
