Hello
I just want to add icinga x509 to my setup but I’m stuck when i try to import certificat into database
fyi, on the release on github Release Icinga Certificate Monitoring v1.1.2 · Icinga/icingaweb2-module-x509 · GitHub We don’t have the postgresql schema include
We need to clone the repo to get it
So I follow the guide for postgresql, I use debian 11 and postgresql 13
psql -l
Liste des bases de données
Nom | Propriétaire | Encodage | Collationnement | Type caract. | Droits d'accès
x509 | x509 | UTF8 | fr_FR.UTF-8 | fr_FR.UTF-8 |
/usr/share/icingaweb2/modules/x509$ sudo icingacli x509 import --file /etc/ssl/certs/ca-certificates.crt
ERROR: PDOException in /usr/share/icinga-php/ipl/vendor/ipl/sql/src/Connection.php:402 with message: SQLSTATE[22021]: Character not in repertoire: 7 ERREUR: séquence d'octets invalide pour l'encodage « UTF8 » : 0x9a
I was thinking it’s because I use fr_FR.UTF-8 so I try to generate En_US UTF local and dropdb/user and recreate it but no luck
So I generate local
/usr/share/icingaweb2/modules/x509$ sudo locale-gen
Generating locales (this might take a while)...
en_US.UTF-8... done
fr_FR.UTF-8... done
Generation complete.
postgres=# CREATE DATABASE x509
WITH OWNER x509
ENCODING 'UTF8'
LC_COLLATE = 'en_US.UTF-8'
LC_CTYPE = 'en_US.UTF-8';
ERREUR: nom de locale invalide : « en_US.UTF-8 »
I use php7.4 and php-gmp / icinga-php* is installed
/usr/share/icingaweb2/modules/x509$ dpkg -l php-gmp
ii php-gmp 2:7.4+76 all GMP module for PHP [default]
/usr/share/icingaweb2/modules/x509$ php -v
PHP 7.4.30 (cli) (built: Jul 7 2022 15:51:43) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.30, Copyright (c), by Zend Technologies
/usr/share/icingaweb2/modules/x509$ dpkg -l "icinga-php*"
ii icinga-php-common 1.0.0-1.bullseye all Icinga PHP Common for Icinga Web 2
ii icinga-php-library 0.10.0-1+debian11 amd64 Icinga PHP Library - IPL
ii icinga-php-thirdparty 0.11.0-1.bullseye amd64 Icinga PHP Thirdparty for Icinga Web 2
If someone got any idea ? I don’t want to move on mysql …
