I am currently experiencing an issue where we are only able to apply 3 permissions to a group. For example, I can have the below 3 permissions added, and the roles.ini file gets parsed correctly, but if I add anything else after the 3 module for module/monitoring, we will then see an exception at the top of the Icinga web page stated an incorrect syntax.
Couldn’t parse the INI file `/etc/icingaweb2/roles.ini’
syntax error, unexpected ‘"’ in Unknown on line 13
For example, here is a set of permissions that works:
[Operators]
groups = “Operator-Admins”
permissions = “module/businessprocess, module/grafana, module/monitoring”
If adding an additional permission, such as monitoring/command/schedule-check, we will see the following when attempting to go into Settings → Access Control.
Here is what appears to break access to that location:
[Operators]
permissions = “module/businessprocess, module/grafana, module/monitoring, monitoring/command/schedule-check”
And this goes for ANY permission added after the 3rd permission. We can adjust the 3 permissions to be anything we would like, but a 4th one breaks it causing an exception.
Unfortunately, we only have the ability to edit these permissions via the config-map roles.ini file, and not directly in Icinga, as even though we have full permissions for everything, we get an access denied.
- Icinga Web 2 version - 2.11.4
- Used modules and their versions (System - About) - Grafana, Icingadb, Monitoring
- Web browser used - Chrome, Edge, etc
- Icinga 2 version used (
icinga2 --version
) - 2.11.4 - PHP version used (
php --version
) - 8.1.2-1ubuntu2.13 - Server operating system and version - Ubuntu Linux
