Hi!
I have an issue which I have no idea how to approach. We have two services that are dependent of each other (outside of Icinga). I’ve declared two hosts in Icinga and each of them have one of those two dependent services. The issue here is that one service is in OK state and the second one is in CRITICAL state and it’s the desired situation, but I would like to see them both as OK state - to make some kind of dependency between them. I already tried working with dependency.conf, but I don’t really think it can help me with this issue.
How would you approach this scenario? If it’s not clear for you, I can explain it further.
