Set up Icinga a while ago but forgot the password, so now I’m trying to reconfigure using
icingacli module enable setup
Problem is almost every step is working in setup, but one;
Read- and writable configuration directory - The directory /etc/icingaweb2 is not writable.
I’ve created a user http who is part of the icingaweb2 group. The permissions on this directory are;
drwxrws— 2 root icingaweb2 4096 Jun 14 22:32 icingaweb2
There’s no selinux running. nginx is running as follows;
ps aux | grep nginx
root 658829 0.0 0.0 12448 2024 ? Ss 22:35 0:00 nginx: master process /usr/bin/nginx -g pid /run/nginx.pid; error_log stderr;
http 658830 0.0 0.0 13160 4716 ? S 22:35 0:00 nginx: worker process
grep icinga /etc/group
icingacmd:x:964:icinga
icinga:x:963:
icingaweb2:x:962:http,icingadirector
icingadirector:x:955:
The system I’m running is Arch Linux, with a nginx webserver and a postgresql backend.
I’m not entirely sure the page is updating, as the php ldap also wasn’t being detected, so I enabled it in /etc/php.ini, and that’s not changed. php -i shows that ldap is enabled. I’ve tried restarting nginx, but no joy.
Thanks for any help.
James
