I have made it to the “Monitoring IDO Resource” part of the setup. But I receive this error whenever I click “Validate Configuration”
There is currently no icinga instance writing to the IDO. Make sure that a icinga instance is configured and able to write to the IDO. Validation Log Connection to icingaido as idouser on localhost: successful have_ssl: YES protocol_version: 10 version: 8.0.17 version_compile_os: Linux Ssl_cipher:
From what I can tell this is a common issue and is caused by improper permissions on the features-available directory, however I have since fixed those permissions and still have the same issue.
[root@icinga features-available]# ls -lah
total 72K
drwxr-x—. 2 icinga icinga 4.0K Jul 25 15:45 .
drwxr-x—. 7 root icinga 160 Jul 25 15:35 …
-rw-rw----. 1 icinga icinga 183 May 23 06:22 api.conf
-rw-rw----. 1 icinga icinga 112 May 23 06:22 checker.conf
-rw-rw----. 1 icinga icinga 140 May 23 06:22 command.conf
-rw-rw----. 1 icinga icinga 159 May 23 06:22 compatlog.conf
-rw-rw----. 1 icinga icinga 235 May 23 06:22 debuglog.conf
-rw-rw----. 1 icinga icinga 193 May 23 06:22 elasticsearch.conf
-rw-rw----. 1 icinga icinga 206 May 23 06:22 gelf.conf
-rw-rw----. 1 icinga icinga 190 May 23 06:22 graphite.conf
-rw-rw----. 1 icinga icinga 302 Jul 25 15:44 ido-mysql.conf
-rw-rw----. 1 icinga icinga 560 May 23 06:22 influxdb.conf
-rw-rw----. 1 icinga icinga 127 May 23 06:22 livestatus.conf
-rw-rw----. 1 icinga icinga 159 May 23 06:22 mainlog.conf
-rw-rw----. 1 icinga icinga 129 May 23 06:22 notification.conf
-rw-rw----. 1 icinga icinga 190 May 23 06:22 opentsdb.conf
-rw-rw----. 1 icinga icinga 146 May 23 06:22 perfdata.conf
-rw-rw----. 1 icinga icinga 225 May 23 06:22 statusdata.conf
-rw-rw----. 1 icinga icinga 127 May 23 06:22 syslog.conf
My ido-mysql.conf:
[root@icinga features-available]# cat /etc/icinga2/features-enabled/ido-mysql.conf
* The IdoMysqlConnection type implements MySQL support
* for DB IDO.
*/object IdoMysqlConnection "ido-mysql" { host = "localhost" //port = 3306 user = "idouser" password = "***" database = "icingaido" cleanup = { downtimehistory_age = 48h contactnotifications_age = 31d } }
And icinga2 is running:
> systemctl status icinga2 -l
● icinga2.service - Icinga host/service/network monitoring system Loaded: loaded (/usr/lib/systemd/system/icinga2.service; enabled; vendor preset: disabled) Active: active (running) since Thu 2019-07-25 15:44:36 MDT; 3 days ago Process: 26443 ExecStartPre=/usr/lib/icinga2/prepare-dirs /etc/sysconfig/icinga2 (code=exited, status=0/SUCCESS) Main PID: 26451 (icinga2)
My OS version:
centos-release-7-6.1810.2.el7.centos.x86_64
Any help would be greatly appreciated.
