But when I remove it, it doesn’t disappear from the list of scheduled downtimes. And if I make changes to the ranges and such, even the comment, it’s not propagated either.
The service is also created through an apply rule, if that’s the issue.
I’m really after a more complex ranges setup, with hours until midnight and weekends. But I don’t think it’s an issue with the ranges. I just cant get rid of the old apply rule until I make a new one. How do I cancel them completely?
Here you can see that I’ve deleted the apply rules, and that they are deployed. But still active under Scheduled Downtimes under /icingaweb2/monitoring/list/downtimes
Not sure how to check if specifically downtimes are checkable, but checks are run on both nodes, yes. Both nodes are recently installed and have the exact same setup. I have a master/master setup with just two nodes, no satellites/agents apart from this.
Exactly. I have even double checked the versions in icingaweb2 and using icinga2 -- version. Because I have upgraded the environment once since installation.
Any Updatre on that, having same issue in a bit different way.
no applyrule to set that downtime but same behavior.
a removed scheduled downtime is not removed from the host/serviceobject it was assingned to
it is still available in icingaweb
but it is removed from database out of the “icinga_scheduled_downtime” table
still every downtime on fs in
ls /var/lib/icinga2/api/packages/_api/53a45f8d-aaea-4873-bc96-0b38dc866eef/conf.d/downtimes/
Display all 39806 possibilities? (y or n)
removing manually in icingaweb
Log says :
[2021-12-15 23:25:13 +0100] information/ExternalCommandListener: Executing external command: [1639607113] DEL_HOST_DOWNTIME;2228
…[2021-12-15 23:25:13 +0100] warning/Downtime: Cannot remove downtime ‘host-bla-bla-bla!c59e6db2-64fc-4214-86eb-464a625f9a17’. It is owned by scheduled downtime object ‘bla bla bla’
API Call remove says 200 successfully removed
But log says:
[2021-12-15 23:23:15 +0100] warning/Downtime: Cannot remove downtime ‘host-bla-bla-bla!c03fc0b5-9b5c-4a2b-9aec-c4c958604080’. It is owned by scheduled downtime object bla bla bla’
[2021-12-15 23:23:15 +0100] information/HttpServerConnection: Request: POST /v1/actions/remove-downtime (from [0.0.0.0]:57334), user: bla, agent: curl/7.68.0, status: OK).
I had to change (or remove) several thousand downtimes, because of wrong date (my fault).
I use module ‘Director’ → ‘Scheduled Downtimes’ (by Apply Rules)
what worked fine for me:
disable (or delete) the wrong ‘ScheduledDowntime Apply Rules’ + deploy
disable the hosts holding the downtime objects + deploy
enable the hosts again + deploy
result:
all nnnn unwanted downtime entries are gone !
now I did setup a regular new ‘Scheduled Downtimes’ Apply Rule (+ deploy).
after a few minutes all correct downtimes appeared nicely.
total used time (incl coffee) aprox. 15 min.
