sajet
(Saje)
1
Hello!
I have defined in secret.conf which is in include_recursive “conf.d”
const WlcPassword = "test"
const WlcUsername = "test"
My host object is defined:
object Host "test.local.com" {
address = "192.168.64.4.3"
check_command = "hostalive"
vars.mac_address = "00999999"
vars.function_v = "am"
vars.serial_number = "80062"
vars.vendor = "Cisco"
vars.model = "Ap300"
if (WlcPassword) {
vars.wlc_password = WlcPassword
if (WlcUsername) {
vars.wlc_username = WlcUsername
I restart icinga2 in I appears error:
critical/config: Error: Error while evaluating expression: Tried to access undefined script variable 'WlcPassword'
Just change it to
And it should work, if constant is not set, the vars will be empty.
dnsmichi
(Michael Friedrich)
3
are you sure that the file is really included in your icinga2.conf? Please share its content.
I’m not able to reproduce this, the below compiles just good.
const UserDefinedConst = "abc"
object Host "user-defined-host" {
check_command = "dummy"
if (UserDefinedConst) {
vars.user_defined_const = UserDefinedConst
sajet
(Saje)
4
The icina2.conf contains:
include "constants.conf"
include "zones.conf"
include <itl>
include <plugins>
include "features-enabled/*.conf"
include_recursive "conf.d"
The file, that contains constant is in directory conf.d/AA/.
If I move file to /etc/icinga2 and include in icinga2.conf then it works.
Best regards
Tadeja
dnsmichi
(Michael Friedrich)
5
Strange. If you put it back there, does it get included when you run config validation in verbose mode?
icinga2 daemon -C -x debug | grep secret
sajet
(Saje)
6
Does not find anything. Whatever in conf/AA or any other directory conf/something are not included. Icinga includes only conf/hosts.
dnsmichi
(Michael Friedrich)
7
are you sure that you’ve edited the correct file and below is just a typo?
Also, you can try to just include the single file instead like this:
include "conf.d/secrets.conf"
sajet
(Saje)
8
I found solution. It was permission of the directory conf/AA. Previous was permission 644, now it works with permission 775.
