TLS error when connecting from Ubuntu 16 "Xenia"
When running the “icigna2 node wizard” on Ubuntu 16 “Xenia”, it fails with a “tlsv1 alert protocol version” during CR auto-signing:
information/cli: Fetching public certificate from master (1.2.3.4, 5665):
warning/TlsStream: OpenSSL error: error:1409442E:SSL routines:ssl3_read_bytes:tlsv1 alert protocol version
critical/cli: Peer did not present a valid certificate.
When I use “curl” to connect to the Icinga server, that works:
curl -kv https://1.2.3.4:5665
* SSL connection using TLS1.2 / ECDHE_RSA_AES_256_GCM_SHA384
< HTTP/1.1 401 Unauthorized
So the system itself does have support for a compatible TLS version.
The client is installed per these guidelines. It fetches the icinga2 packages from:
/etc/apt/sources.list.d/xenial-icinga.list:
deb [signed-by=/usr/share/keyrings/icinga-archive-keyring.gpg] https://packages.icinga.com/ubuntu icinga-xenial main
deb-src [signed-by=/usr/share/keyrings/icinga-archive-keyring.gpg] https://packages.icinga.com/ubuntu icinga-xenial main
Icinga client version: r2.4.1-1
Icinga server version: r2.13.7-1
It looks like the Icinga client uses an old TLS version, despite the OS being capable of doing TLS v1.2.
What options can I explore to connect to the server?
Ubuntu 16 is no longer supported, but there is a icinga2 version available that “should” still work in your setup: icinga2-bin_2.12.3-1.xenial_i386.deb
try to find out why you installed icinga 2.4.1-1 instead of 2.12.3
It turns out the Icinga repository wasn’t trusted, so it pulled the agent from a default source. The command to save the Icinga repository key must have failed without me noticing it.
It’s now connected to the satellite. Thanks for the hint!
