I have a setup with 1 icinga master + 1 seperate icingaweb instance.
My Database and IDO feature are only running on the Master.
I want to make the connection from the websetup to my master and have remote access to my database.
But when i connect to it, i get the message: There is currently no icinga instance writing to the IDO
output of icinga2 object list -t IdoMysqlConnection:
Object ‘ido-mysql’ of type ‘IdoMysqlConnection’:
% declared in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 3:1-3:37
- __name = “ido-mysql”
- categories = [ “DbCatConfig”, “DbCatState”, “DbCatAcknowledgement”, “DbCatComment”, “DbCatDowntime”, “DbCatEventHandler”, “DbCatFlapping”, “DbCatNotification”, “DbCatProgramStatus”, “DbCatRetention”, “DbCatStateHistory” ]
- cleanup
- database = “ido_user”
% = modified in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 8:3-8:24 - enable_ha = true
- enable_ssl = false
- failover_timeout = 30
- host = “192.150.1.1”
% = modified in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 6:3-6:22 - instance_description = “”
- instance_name = “default”
- name = “ido-mysql”
- package = “_etc”
- password = “fsdafgsadfdsf”
% = modified in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 5:3-5:31 - port = 3306
% = modified in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 7:3-7:13 - socket_path = “”
- source_location
- first_column = 1
- first_line = 3
- last_column = 37
- last_line = 3
- path = “/etc/icinga2/features-enabled/ido-mysql.conf”
- ssl_ca = “”
- ssl_capath = “”
- ssl_cert = “”
- ssl_cipher = “”
- ssl_key = “”
- table_prefix = “icinga_”
- templates = [ “ido-mysql” ]
% = modified in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 3:1-3:37 - type = “IdoMysqlConnection”
- user = “ido_user”
% = modified in ‘/etc/icinga2/features-enabled/ido-mysql.conf’, lines 4:3-4:20 - zone = “”
So i really stuck here. I have an IDO running on my master, and icingaweb can read from it, but it tells me that no ido is writing?
library “db_ido_mysql”
object IdoMysqlConnection “ido-mysql” {
user = “ido_user”,
password = “afsdajfasjdfasdä”
host = “192.150.1.1” //this is my master
port = 3306
It seems that icingaweb just isnt aware of the ido, even if it can connect to the IDO database. Some help on this would be really nice.
Best Regards
ghost
