Theming and DIY Info
Theming
Themes are a nice way to customize the look and feel of your own Icinga Web 2.
In this Thread we would like to Introduce some nice themes.
Installation
The Module can be found here
How to install the module can be found here
Themes
Here is a small selection of Themes for inspiration:
company example Theme
Installation
The Theme can be found here
Unicorn Theme
Installation
always green Theme
This Theme changes just the Icinga Web 2 color scheme after the login screen.
Installation
Icinga Web 2 dark Theme
Installation
Icinga Web 2 Batman Light Theme
Installation
Other Theming Resources
There is also the Icinga Exchange where you can find other Themes from other Developers
These can be found here
How to Customize a Theme
To Do’s
Please if you would like to add an tutorial beside the explanations inside of the shown Themes we encourage everyone and to write your own guides and tuts here for the community. The form in which you do that can be written :open_book: or :video_camera: it can be visual like a screencast as well.
Hello together!
I updated the broken links here, so all of the info is all fresh and working again!
Do you have any cool themes you want to share?
Feel free to do that here!
Feu
I had a try at creating a true dark theme for Icinga Web 2
Check it out:
https://github.com/lazaroblanc/icingaweb2-dark-theme
https://exchange.icinga.com/lazaroblanc/A%20true%20dark%20theme
I’m using the solarized-dark theme that comes with icinga, but it has some ‘bugs’ I’d like to fix. For example, the “notification-bar” (the one that appears if you submit a form, e.g. ACK, Downtime…) on the bottom of the page is white text on bright yellow and not readable.
I’ve already color-picked the background-color but couldn’t find it anywhere in the css-files.
How is the bg / fg color for this “notification-bar at the bottom” called?
I took a closer look at lazaroblanc theme, it uses green as bg-color for that, I can’t figure out where it is set.
Any hints?
Hey hey,
you might want to start looking at the
public/css/themes/solarized-dard.less in
It would probably help to read up on less and it’s variable system before too :slight_smile:
Then feel free to open a pull request on the GitHub!
If you need any help, let me know :slight_smile:
