General
Look into the render api and adjust this for your templates. This docs entry also highlights that for example bgcolor can be set on a global basis in graphite itself.
https://icinga.com/docs/graphite/latest/doc/04-Templates/
urlparams … and you can even define them on a global basis in your config.ini file.
Template Examples
The module provides a common set of templates already. Please share your own examples below.
Full area and min/max values
[powerprctg.graph]
check_command = “check_batteryprctg”
[powerprctg.metrics_filters]
rta.value = “$service_name_template$.perfdata.$perfdata_label$.value”
[powerprctg.urlparams]
areaMode = "all"
yMin = "0"
yMax = “100”
