The instructions that I’ve found to add extra admin users to the icingaweb all say to log in and go to configuration/authentication/users/add new user.
I even found icinga2 - icingaweb2 create new user - YouTube which walks me through the process.
Sadly, my freshly deployed icingaweb (v1.9.1)
How do I add these options to my navigation pane? I could not find any instructions on this. (Search is not your friend here, these terms are usually used in a very different context)
Is it possible to create a new icingaweb admin user using command line/config files?
If not, could I just insert new users directly into the icingaweb_user && icingaweb_group_membership tables and have that work?
