Switching to IcingaDB from monitoring module leaves two broken links
I have recently installed IcingaDB on our two icinga master and I was trying to switch completely from the monitoring module to the icingadb module in icingaweb2.
However, the first to items on the current incidents dashboard are not translated to icingadb urls, i.e. I’ll get an error:
Service Problems
Page not found. Enabling the "monitoring" module might help!
and the URLs remain like this:
Current Incidents
Service Problems        monitoring/list/services?service_problem=1&limit=10&sort=service_severity
Recently Recovered Services     monitoring/list/services?service_state=0&limit=10&sort=service_last_state_change&dir=desc
All other URLs for the dashboards are correctly translated to icingadb, i.e. the “Host Problems” uses icingadb.
While the monitoring module is enabled, I can use the “Preview this in IcingaDB” links for the current incidents dashboard and all three are translated to IcingaDB. So, it can translate them correctly but it doesn’t for those two on the dashboard, if the monitoring module is disabled.
I’m puzzled what is so special about those two. If I understand correctly, those are the default dashboard URLs…
Still running on CentOS 7. Icinga RPMs installed:
icinga2-2.14.0-1.el7.x86_64
icinga2-bin-2.14.0-1.el7.x86_64
icinga2-common-2.14.0-1.el7.x86_64
icinga2-ido-mysql-2.14.0-1.el7.x86_64
icinga2-selinux-2.14.0-1.el7.x86_64
icingacli-2.11.4-2.el7.noarch
icingadb-1.1.1-1.el7.x86_64
icingadb-redis-7.0.5-1.el7.icinga.x86_64
icingadb-redis-doc-7.0.5-1.el7.icinga.noarch
icingadb-web-1.0.2-1.el7.noarch
icinga-l10n-1.2.0-1.el7.icinga.noarch
icinga-php-common-1.0.0-1.el7.icinga.noarch
icinga-php-library-0.12.0-1.el7.noarch
icinga-php-thirdparty-0.11.0-1.el7.icinga.noarch
icinga-selinux-common-1.0.0-1.el7.icinga.noarch
icingaweb2-2.11.4-2.el7.noarch
icingaweb2-common-2.11.4-2.el7.noarch
icingaweb2-selinux-2.11.4-2.el7.noarch
icingaweb2-vendor-dompdf-2.11.4-2.el7.noarch
icingaweb2-vendor-HTMLPurifier-2.11.4-2.el7.noarch
icingaweb2-vendor-JShrink-2.11.4-2.el7.noarch
icingaweb2-vendor-lessphp-2.11.4-2.el7.noarch
icingaweb2-vendor-Parsedown-2.11.4-2.el7.noarch
icingaweb2-vendor-zf1-2.11.4-2.el7.noarch
php-icinga-2.11.4-2.el7.noarch
vim-icinga2-2.14.0-1.el7.x86_64
rh-php73-php-fpm-7.3.33-1.el7.x86_64
Am I the only one with this problem? Is this the right category for this? Or is this a icingaweb2 issues?
