Hi community,
I am using director and I have created some simple SNMP monitoring services and attached it in a serviceset that applies to machines that has a host address attribute.
the strange thing is, some check_commands are throwing the error: “execvpe(/usr/lib64/nagios/plugins/check_snmp_mem.pl) failed: No such file or directory”
below you see how a host looks like in my monitoring view
I know that has been published before and I searched many threads, I have never found similar scenario where some services (not all of them) are working and the rest is not!!
I can assure that the files are all located in the plugins folder
when I click on inspect everything looks to be fine
Well, I dont think its backend misconfiguration issue because the issue is affecting some services and NOT all of them! however the backend is added to the Hosts and looks like this
I would appreciate any advice
thanks in advance
Jaber
