Hi experts,
I have few silly questions. So in few weeks from now we will go in some major infrastructure change and cause of that reason we will need turn off all our notifications. We have a lot notification rules even a few notification scripts written in python.
I am searching easiest solution how to disable with 1 click all of them. I think I have found it but not quite sure if this could take a place.
So over web gui/icingaweb2 have found
and under the “feature commands” we can see switch off button for notification.
- If I switch off this button this will silence all notifications, everything?
- If it is so, if I switch back to ON it will not overwrite “notification_enable” for some service or host objects where normally should be OFF?
- what about icinga2 feature disable notification? on GUI notification is still ON after “icinga2 feature disable notification” (ofc I did restart)
[root@monitorigmaster ~]# icinga2 feature disable notification
Disabling feature notification. Make sure to restart Icinga 2 for these changes to take effect.
Didnt found much here Monitoring Basics - Icinga 2
Thx for help/advice.
