Status check stuck on pending when monitoring agent
Hello Dear,
I would kindly ask for your support regarding the pending state i have when trying to monitor disk of my agent.
I tried to setup an environment composed of a Master, Satellite and an Agent.
I have Icinga director installed on the master. From where i have setup:
  • a single service Template and i add it to the serviceSet (service template has the disk check)
  • Then i created a host template to which i added the serviceSet
  • Then i created a host with the host template to check the disk status on the host
    Screen Shot 2021-06-02 at 21.41.57
  • Find the result in the attached image
  • Here is the config of the Master Zone /etc/icinga2/zones.conf
object Endpoint “master.domain.dc” {
object Zone “master” {
endpoints = [ “master.domain.dc” ]
global = true
global = true
object Endpoint “satellite.domain.dc” {
host = “x.x.x.3”
object Zone “satellite” {
endpoints = [ “satellite.domain.dc” ]
parent = “master”
  • Here is the config of the Satellite Zone /etc/icinga2/zones.conf
parent = “master”
object Endpoint “agent.domain.dc” {
host = “x.x.x.4”
object Zone “agent.domain.dc” {
endpoints = [ “agent.domain.dc” ]
parent = “satellite”
global = true
global = true
  • Here is the config of the Agent Zone /etc/icinga2/zones.conf
global = true
global = true
Note that there is no problem regarding the certificate signing
I am willing to share more info regarding the setup if you need it.
Best Regards,
Cherif
The director is handling zone and endpoint objects for agents. Hence, you don’t need to define them manually in satellite’s zones.conf.
you are right, thank you very much
