Hey guys…
We are having a bunch of SSL to check, and I would like to know how are you doing it on your side…
Are you having a list? Are you having a “dumb” host ?
Need some idea
Hey guys…
Need some idea
Hi.
I am not sure what you exactly mean, but maybe this is what you are searching for:
See here
Greetings.
yeah it’s part of my question! I was curious to see how people are “checking” their SSL certificate using icinga2!
I’m using the idea of the link you post but having a little question…
Using something like
apply Service "Certificate " for (vhost in host.vars.vhosts_ssl) {
it will create a service called “Certificate andthevalue”
How can I name my service “Certicate [andthevalue]”
EDIT:
solution is
name = “SSL [” + vars.http_vhost + “]”
display_name = “SSL [” + vars.http_vhost + “]”
