SQL statement to find out, which object has not notification configured
Hi guys,
Icinga2 version: r2.13.1-1
Operating System: Debian 9
I search for an MySQL statement to figure out, which host or service object has not be configured to use a given “Contact” and “Contactgroup”
E.g.:
I have a contact “testcontact” and Contactgroup “testcontactgroup” and have attached it to may all host and services. Now I want to figure out, to which hosts/services it is not attached.
Any help is appreciated.
Kind regards
Peer-Mario
That’s what Icinga Web 2 issues to fetch notifications, their contacts and hosts/services. Though, you have to adjust it to your needs first:
SELECT n.id,
       n.host_display_name,
       n.host_name,
       n.notification_contact_name,
       n.notification_output,
       n.notification_state,
       n.notification_timestamp,
       n.service_description,
       n.service_display_name
FROM ((SELECT hn.notification_id            AS id,
              h.display_name                AS host_display_name,
              ho.name1                      AS
                                               host_name,
              co.name1                      AS notification_contact_name,
              hn.output                     AS
              hn.state                      AS notification_state,
              UNIX_TIMESTAMP(hn.start_time) AS notification_timestamp,
              NULL                          AS
              NULL                          AS service_display_name
       FROM icinga_notifications
                AS hn
                INNER JOIN icinga_objects AS ho ON ho.object_id = hn.object_id AND
                                                   ho.is_active = 1 AND ho.objecttype_id = 1
                INNER JOIN icinga_hosts AS h ON h.host_object_id = ho.object_id
                LEFT JOIN icinga_contactnotifications AS cn ON cn.notification_id =
                                                               hn.notification_id
                LEFT JOIN icinga_objects AS co ON co.object_id = cn.contact_object_id AND
                                                  co.is_active = 1 AND co.objecttype_id = 10
       GROUP BY hn.notification_id,
                co.object_id,
                ho.object_id,
                h.host_id)
      UNION ALL
      (SELECT sn.notification_id            AS id,
              h.display_name                AS
                                               host_display_name,
              so.name1                      AS host_name,
              co.name1                      AS
              sn.output                     AS notification_output,
              sn.state                      AS
                                               notification_state,
              UNIX_TIMESTAMP(sn.start_time) AS
              so.name2                      AS service_description,
              s.display_name                AS
       FROM icinga_notifications AS sn
                INNER JOIN icinga_objects AS so ON so.object_id = sn.object_id AND
                                                   so.is_active = 1 AND so.objecttype_id = 2
                INNER JOIN icinga_services AS s ON s.service_object_id = so.object_id
                INNER JOIN icinga_hosts AS h ON h.host_object_id = s.host_object_id
                                                               sn.notification_id
       GROUP BY sn.notification_id,
                co.object_id,
                so.object_id,
                h.host_id,
                s.service_id)) AS n
ORDER BY n.notification_timestamp DESC;
Thanks Johannes,
for your answer. The issue here is to understand this statement. I have only basis knowledge in SQL but it will may help, If I show this statment to an SQL expert.
Kind regards
Peer-Mario
