i am willing to query all hosts joined with a specific custom variable (“guest_fullname”).
But the join does not work since instance_id are not equal on tables icinga_hosts and icinga_customvariables.
Could you help me out on this query?
Is there a actual database schema available?
The only one I could find is this one: https://fossies.org/linux/misc/old/icinga-core-1.14.2.tar.gz/icinga-core-1.14.2/html/docs/images/db_model_ht.png
SELECT icinga_hosts.instance_id,address,display_name,varvalue FROM icinga_hosts JOIN icinga_customvariables IC ON IC.instance_id = icinga_hosts.instance_id WHERE varname LIKE 'guest_fullname'
