hello team,
I’m using https://www.monitoring-plugins.org/doc/man/check_snmp.html for querying MIB. As a result, I get this ugly output.
Is there an easy way to filter the output just to show an exact string? In this example a just the version.
Maybe someone can point to the existing SNMP plugin or we can set a pattern using Icinga DSL?
mj
