Hello Team,
I have configured icinga2 on linux server. Everything is working as expected but for Host and Service I am receiving notification only for ping4 service. For other services I am not getting notification on slack and PagerDuty. Here is the output of icinga2 object list --type Notification
I want notification for all services.
Object ‘saaskarma!ping4!pagerduty-service’ of type ‘Notification’:
% declared in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 75:1-75:49
- __name = “saaskarma!ping4!pagerduty-service”
- command = “notify-service-by-pagerduty”
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 76:3-76:41 - command_endpoint = “”
- host_name = “saaskarma”
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 75:1-75:49 - interval = 1800
- name = “pagerduty-service”
- package = “_etc”
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 75:1-75:49 - period = “24x7”
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 79:3-79:17 - service_name = “ping4”
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 75:1-75:49 - source_location
- first_column = 1
- first_line = 75
- last_column = 49
- last_line = 75
- path = “/etc/icinga2/conf.d/pagerduty-icinga2.conf”
- states = [ “OK”, “Warning”, “Critical”, “Unknown” ]
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 77:3-77:45 - templates = [ “pagerduty-service” ]
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 75:1-75:49 - times = null
- type = “Notification”
- types = [ “Problem”, “Acknowledgement”, “Recovery” ]
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 78:3-78:48 - user_groups = null
- users = [ “pagerduty” ]
% = modified in ‘/etc/icinga2/conf.d/pagerduty-icinga2.conf’, lines 80:3-80:25 - vars = null
- zone = “master”
Object ‘saaskarma!ping4!slack-notifications-notification-services’ of type ‘Notification’:
% declared in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 66:1-66:73
- __name = “saaskarma!ping4!slack-notifications-notification-services”
- command = “slack-notifications-command”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 45:5-45:43 - command_endpoint = “”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 66:1-66:73 - interval = 900
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 12:5-12:18 - name = “slack-notifications-notification-services”
- package = “_etc”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 66:1-66:73 - period = “24x7”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 10:5-10:19 - service_name = “ping4”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 66:1-66:73 - source_location
- first_column = 1
- first_line = 66
- last_column = 73
- last_line = 66
- path = “/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 51:5-51:47 - templates = [ “slack-notifications-notification-services”, “slack-notifications-user-configuration-services”, “slack-notifications-default-configuration-services”, “slack-notifications-configuration”, “slack-notifications-user-configuration”, “slack-notifications-default-configuration” ]
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-user-configuration.conf’, lines 12:1-12:71
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 48:1-48:74
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 42:1-42:57
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-user-configuration.conf’, lines 1:0-1:61
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 1:0-1:64 - times = null
- types = [ “Problem”, “Acknowledgement”, “Recovery”, “Custom”, “FlappingStart”, “FlappingEnd” ]
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 6:5-7:42 - user_groups = null
- users = [ “slack-notification-user” ]
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 8:5-8:41 - vars
- slack_notifications_botname = “icinga”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 15:5-15:47 - slack_notifications_channel = “#icinga-rawneg”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 14:5-14:55 - slack_notifications_color_dictionary
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 17:5-24:5- CRITICAL = “danger”
- DOWN = “danger”
- OK = “good”
- UNKNOWN = “grey”
- UP = “good”
- WARNING = “warning”
- slack_notifications_icinga2_base_url = “https://icinga.raweng.net”
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-user-configuration.conf’, lines 5:5-5:75 - slack_notifications_icon_dictionary
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 25:5-39:5- ACKNOWLEDGEMENT = “ballot_box_with_check”
- CRITICAL = “red_circle”
- CUSTOM = “speaking_head_in_silhouette”
- DOWNTIMEEND = “arrow_down_small”
- DOWNTIMEREMOVED = “leftwards_arrow_with_hook”
- DOWNTIMESTART = “arrow_up_small”
- FLAPPINGEND = “small_red_triangle_down”
- FLAPPINGSTART = “small_red_triangle”
- OK = “large_blue_circle”
- PROBLEM = “red_circle”
- RECOVERY = “large_blue_circle”
- UNKNOWN = “grey_question”
- WARNING = “bell”
- slack_notifications_plugin_output_max_length = 3500
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-configuration.conf’, lines 16:5-16:60 - slack_notifications_webhook_url = “Unlock your productivity potential with Slack Platform | Slack
% = modified in ‘/etc/icinga2/conf.d/slack-notifications/slack-notifications-user-configuration.conf’, lines 4:5-4:124
- zone = “master”
