i would like use icinga distributed monitoring system with one Master server - mon-master (icingaweb2 + ido + icingadb + icingadb_web + icinga director) and two checkers (endpoints). I need monitor the hosts on different nodes, for example: one host i want monitor only via mon-int and next host i will monitor via mon-web. And this works via Director perfectly (I set for each host the cluster-zone).
Now i have set zone.conf :
object Endpoint "mon-master" {
object Zone "master" {
endpoints = [ "mon-master" ]
object Endpoint "mon-int" {
object Zone "mon-int" {
endpoints = [ "mon-int" ]
parent = "master"
object Endpoint "mon-web" {
object Zone "mon-web" {
endpoints = [ "mon-web" ]
parent = "master"
global = true
global = true
Now i need monitoring first host with service on both endpoints (mon-int and mon-web), but doesn’t work.
I tried add the new zone, but this change do not accept Icinga (critical/config: Error: Endpoint ‘mon-x’ is in more than one zone.) :
object Zone "all-checkers" {
endpoints = [ "mon-int", "mon-web" ]
parent = "master"
Can you please help me ?
Many thanks.
