Setup stuck in requirements
Hi all,
I can’t continue the setup after checking the requirements. It looks like there is more at the bottom of the page, but I can’t scroll down. Tested with multiple browsers.
You can decrease your zoom level e.g. using CTRL + -
Woaaah that was quick, thanks!!
