Do we have any document or any kind of links for setting up Icinga2 using Azure?
Could not find any related document. Can anyone please help us with this?
Thanks,
Sai
Thanks,
Sai
Do you mean an Azure-hosted Virtual Server (in which case you should follow
the instructions for whichever Linux distribution you choose to use), or
something else? I’m not quite sure what “using Azure” means in this instance.
Antony.
Yes using Azure hosted virtual server
In that case you don’t need any special instructions. Simply select the
distribution of your choice from the list at
Installation - Icinga 2 and proceed as
for any other type of hosted machine.
Just beware that Azure VMs come with a pretty closed default firewall, which
you may have to adjust for your network connections.
Antony.
Okay, Let me try this!!
Thanks,
Saicharan
