Setting up Icinga Web DB for Local Auth - Cannot Access DB
Hello All,
Not sure what I’m missing here. I’ve set up two Icinga masters in an HA pair in prod and didn’t have this issue.
I’m currently trying to set up a test master (single master needed only - for basic change testing). When I get to the step to do the web setup, I get to the point where it asks me for authentication backend information. I like to set up local first as a break-glass option and use LDAP later as well if needed or wanted.
When setting up local auth via mariadb (as I did on prod masters), I’m running into an issue where it’s telling me the user can’t create the necessary schema (I’m guessing). I’ve created the DB, logged into it using the user I’m specifying and tested creating a table there (dropped afterward) and it works. Also tried using root creds.
Anyone ever see this issue?
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.2-1)
System information:
  Platform: Debian GNU/Linux
  Platform version: 12 (bookworm)
  Kernel: Linux
  Kernel version: 6.1.0-18-amd64
  Architecture: x86_64
Build information:
  Compiler: GNU 12.2.0
  OpenSSL version: OpenSSL 3.0.11 19 Sep 2023
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
php --version
PHP 8.2.7 (cli) (built: Jun  9 2023 19:37:27) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.7, Copyright (c) Zend Technologies
    with Zend OPcache v8.2.7, Copyright (c), by Zend Technologies
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Trying to use DB creds that I’ve created that do work when altering the DB on CLI (same as I did on HA master pair in prod)
Trying to use root creds for DB
Guessing here, but I would assume the provided credentials do really not work :slight_smile:
The problem MIGHT be, that users in mysql/mariadb are often defined as username@host/ip and therefore you might try to login as a different user depending on whether you use localhost/127.0.0.1 or the “public” address of the machine.
also, is there really a database user called “root” or did you just try the root account of the linux machine?
Please add an example here on how specifically you tried (succesfully) to login into the database on the CLI
EDIT: As a note, the icingadbweb_test user host is localhost as I’ve got the authentication DB installed locally instead of on my DB server.
EDIT 2: Also tried exporting DB schema from production and importing on this test box, still not working.
Thanks for the input Lorenz! Here is what you asked for:
# mariadb -u icingadbweb_test -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 37
Server version: 10.11.6-MariaDB-0+deb12u1 Debian 12
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> show databases;
| Database           |
| icingadbweb_test   |
| information_schema |
2 rows in set (0.002 sec)
use icingadbweb_test;
Database changed
MariaDB [icingadbweb_test]> create table test_table(a int);
Query OK, 0 rows affected (0.009 sec)
MariaDB [icingadbweb_test]> show tables;
| Tables_in_icingadbweb_test |
| test_table                 |
1 row in set (0.001 sec)
MariaDB [icingadbweb_test]> exit;
Bye
# mariadb -u root -p
Enter password:
Your MariaDB connection id is 38
MariaDB [(none)]> select user, host from mysql.user;
| User             | Host      |
| icingadbweb_test | localhost |
| mariadb.sys      | localhost |
| mysql            | localhost |
| root             | localhost |
4 rows in set (0.003 sec)
MariaDB [(none)]> show grants for icingadbweb_test@localhost;
| Grants for icingadbweb_test@localhost        |
| GRANT USAGE ON *.* TO `icingadbweb_test`@`localhost` IDENTIFIED BY PASSWORD 'password_hash' |
| GRANT ALL PRIVILEGES ON `icingadbweb_test`.* TO `icingadbweb_test`@`localhost`                                          |
hm, ok
I think the mariadb tool uses some unix socket by default, could you try mariadb -u icingadbweb_test -p --hostname localhost?
Also, this icingadbweb_test user is the one you tried in the web interface?
No --hostname flag, but I did run mariadb -u icingadbweb_test -p --host localhost and it worked as expected. Yes, this is the same user I tried in the web interface.
# mariadb -u icingadbweb_test -p --host localhost
Enter password:
Your MariaDB connection id is 99
| Database           |
| icingadbweb_test   |
2 rows in set (0.001 sec)
MariaDB [(none)]> use icingadbweb_test;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
| icingaweb_group            |
| icingaweb_group_membership |
| icingaweb_rememberme       |
| icingaweb_schema           |
| icingaweb_user             |
| icingaweb_user_preference  |
6 rows in set (0.001 sec)
Query OK, 0 rows affected (0.008 sec)
| icingaweb_group            |
| icingaweb_schema           |
| icingaweb_user             |
| test_table                 |
7 rows in set (0.001 sec)
MariaDB [icingadbweb_test]> drop table test_table;
Query OK, 0 rows affected (0.005 sec)
Hey @lorenz - any ideas here? I even rebuilt a server just to run into the same issue. Not sure what’s happening as this did not happen with either of the production instances I’ve stood up that are currently working with the same exact configuration.
Thanks!
Figured this out - I’ll be putting a bug report in on the icingaweb2 github. Changing the DB name to “icingaweb2” fixed this. Appears the icingaweb2 application doesn’t play well with DB names that have an underscore in the name, although it’s permitted in MariaDB/MySQL syntax (provided the DB name doesn’t BEGIN with an underscore).
funny, never would have thought of that. :+1:
