One of our satellite zones has randomly stopped checking in, and after enabling debuglog on the master node, I can see the following message:
[2023-03-21 14:13:26 +1100] notice/ApiListener: Setting log position for identity 'satellite.zone': 2023/06/12 21:53:19
However, on the satellite in question, I can see checks are all running correctly and as expected:
[2023-03-21 14:20:20 +1100] debug/Checkable: Update checkable 'REDACTED!CPU Load' with check interval '300' from last check time at 2023-03-21 14:20:20 +1100 (1.67937e+09) to next check time at 2023-03-21 14:25:05 +1100 (1.67937e+09).
[2023-03-21 14:20:20 +1100] notice/ApiListener: Relaying 'event::SetNextCheck' message
[2023-03-21 14:20:20 +1100] notice/ApiListener: Sending message 'event::SetNextCheck' to 'master'
[2023-03-21 14:20:20 +1100] notice/ApiListener: Relaying 'event::CheckResult' message
[2023-03-21 14:20:20 +1100] notice/ApiListener: Sending message 'event::CheckResult' to 'master'
[2023-03-21 14:20:20 +1100] notice/Process: PID 6838 ('/usr/lib64/nagios/plugins/thola' '--no-cache' '--snmp-community' 'REDACTED' 'check' 'interface-metrics' '10.0.99.9' '--snmp-version' '2c') terminated with exit code 0
[2023-03-21 14:20:20 +1100] debug/Checkable: Update checkable 'REDACTED!SNMP Interface Utilisation' with check interval '60' from last check time at 2023-03-21 14:20:20 +1100 (1.67937e+09) to next check time at 2023-03-21 14:21:16 +1100 (1.67937e+09).
I have checked all the usual spots - NTP is configured and working on all hosts, and we have 102 other zones all connected and working correctly - it’s just this specific zone.
I’ve configured the satellite on a new VM, but the same behaviour is occurring - which makes me think the master node is doing this somehow.
The satellite zone appears connected to the master zone, but all services in IcingaWeb appear as overdue.
Master node is running r2.13.6-1 and satellite node is running r2.13.7-1.
Is this a bug I should raise on GitHub? Essentially what I think has happened is NTP or the HW clock on the host has jumped into the future, a whole heap of checks isolated to one zone got scheduled 3 months into the future, and then the clock recovered, but the checks remain stuck in the future.
Ah I did not think about that - that satellite would have pulled the latest version - I’ll pin it to the same as the master.
Having said that, this issue was occurring before upgrading to the latest - I believe they were both on the same version previously, but I wanted a clean slate and rebuilt the VM.
I’ve had a look through the code to identify where the timestamp is pulled from, but I can’t seem to find the definition of this function:
I have downgraded the satelilte node to be the same version as the master node, but still same behaviour:
[root@satellite ~]# icinga2 -V
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.6-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-957.el7.x86_64
Architecture: x86_64
[root@satellite ~]# date
Wed Mar 22 09:52:20 AEDT 2023
[root@master ~]# icinga2 -V
System information:
Kernel: Linux
Kernel version: 3.10.0-1160.15.2.el7.x86_64
[root@master ~]# date
Wed Mar 22 09:52:53 AEDT 2023
The behaviour I am seeing is that the zone is connected, but no host or service check results are being accepted by the master node - this includes both checks running from the satellite node, and hosts within the zone running Icinga Agent.
100% sure - I can see both on the master and the satellite node they are connected (and all zone checks are passing).
I ended up stopping the master, renaming the icinga2.state file and restarting and everything has come good.
I realised I encountered this same issue in 2020, so I ran the same troubleshooting steps and deleting the state file resolved it.
Is this something I should raise as an issue in GitHub? I’ve had a look through the source code and it appears that the master should be handling checks that have a future timestamp, but in my case I was only seeing that the “log position” was three months into the future.
