Hello everyone,
I have been setting up Icinga2 from scratch for the last weeks for the first time.
Currently i am facing an issue with mail notifications.
The mail function worked for me without any problem, when i tried them in the /conf.d directory, befor making icinga to master node
Since i changed my icinga2 to a master node and used the /zones.d directory with different file and folder structure i cannot sent mails without them being forced.
I particularly have that problem by trying to send custom mail. i can only send them when being forced, i do receive automatic mail warnings from my agent.
if anyone, would have an advice on what needs to be changed or added that would be great!
here are the icinga2 version infos:
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.7-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
Platform: Ubuntu
Platform version: 22.04.2 LTS (Jammy Jellyfish)
Kernel: Linux
Kernel version: 5.15.0-71-generic
Architecture: x86_64
Build information:
Compiler: GNU 11.3.0
OpenSSL version: OpenSSL 3.0.2 15 Mar 2022
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
my overall config is in /etc/icinga2/zones.d/global-templates/test.conf
and looks like that:
template Host "generic-host" {
max_check_attempts = 3
check_interval = 1m
retry_interval = 30s
check_command = "hostalive"
apply Service "apt"{
check_command = "apt"
check_interval = 12h
retry_interval = 1h
assign where (host.address || host.address6) && host.vars.os == "Linux"
apply Service "ping4" {
check_command = "ping4"
assign where host.address
apply Service "ssh" {
check_command = "ssh"
apply Service for (http_vhost => config in host.vars.http_vhosts) {
check_command = "http"
vars += config
assign where host.vars.client_endpoint
apply Service "disk" {
check_command = "disk"
apply Service "icinga" {
check_command = "icinga"
apply Service "load" {
check_command = "load"
/* Used by the ScheduledDowntime apply rule in `downtimes.conf`. */
vars.backup_downtime = "02:00-03:00"
apply Service for (procs in host.vars.procs) {
check_command = "procs"
vars.procs_critical = "1:"
vars.procs_command = procs
apply Service for (argument in host.vars.runsv) {
vars.procs_command = "runsv"
vars.procs_argument = argument
apply Service "procs" {
apply Service "swap" {
check_command = "swap"
apply Service "users" {
check_command = "users"
template User "generic-user" {
object User "icingaadmin" {
import "generic-user"
enable_notifications = true
states = [ OK, Warning, Critical ]
types = [ Problem, Recovery ]
display_name = "Icinga 2 Admin"
groups = [ "icingaadmins" ]
email = "XXXXXXXX"
object UserGroup "icingaadmins" {
display_name = "Icinga 2 Admin Group"
apply Notification "mail-icingaadmin" to Host {
import "mail-host-notification"
user_groups = host.vars.notification.mail.groups
users = host.vars.notification.mail.users
assign where host.vars.notification.mail
interval = 60m
vars.notification_logtosyslog = true
apply Notification "mail-icingaadmin" to Service {
import "mail-service-notification"
interval = 60m
template Notification "mail-host-notification" {
command = "mail-host-notification"
states = [ Up, Down ]
types = [ Problem, Acknowledgement, Recovery, Custom,
FlappingStart, FlappingEnd,
DowntimeStart, DowntimeEnd, DowntimeRemoved ]
vars += {
notification_from = "Icinga 2 Service Monitoring<XXX>"
notification_logtosyslog = false
period = "24x7"
template Notification "mail-service-notification" {
command = "mail-service-notification"
states = [ OK, Warning, Critical, Unknown ]
vars += {
period = "24x7"
object NotificationCommand "mail-host-notification" {
command = [ SysconfDir + "/icinga2/scripts/mail-host-notification.sh" ]
arguments += {
"-4" = {
required = true
value = "$notification_address$"
"-6" = "$notification_address6$"
"-b" = "$notification_author$"
"-c" = "$notification_comment$"
"-d" = {
required = true
value = "$notification_date$"
"-f" = {
value = "$notification_from$"
description = "Set from address. Requires GNU mailutils (Debian/Ubuntu) or mailx (RHEL/SUSE)"
"-i" = "$notification_icingaweb2url$"
"-l" = {
required = true
value = "$notification_hostname$"
"-n" = {
required = true
value = "$notification_hostdisplayname$"
"-o" = {
required = true
value = "$notification_hostoutput$"
"-r" = {
required = true
value = "$notification_useremail$"
"-s" = {
required = true
value = "$notification_hoststate$"
"-t" = {
required = true
value = "$notification_type$"
"-v" = "$notification_logtosyslog$"
vars += {
notification_address = "$address$"
notification_address6 = "$address6$"
notification_author = "$notification.author$"
notification_comment = "$notification.comment$"
notification_type = "$notification.type$"
notification_date = "$icinga.long_date_time$"
notification_hostname = "$host.name$"
notification_hostdisplayname = "$host.display_name$"
notification_hostoutput = "$host.output$"
notification_hoststate = "$host.state$"
notification_useremail = "$user.email$"
object NotificationCommand "mail-service-notification" {
command = [ SysconfDir + "/icinga2/scripts/mail-service-notification.sh" ]
arguments += {
"-4" = {
required = true
"-d" = {
required = true
"-e" = {
required = true
value = "$notification_servicename$"
"-f" = {
"-l" = {
required = true
"-n" = {
required = true
"-o" = {
required = true
value = "$notification_serviceoutput$"
"-r" = {
required = true
"-s" = {
required = true
value = "$notification_servicestate$"
"-t" = {
required = true
"-u" = {
required = true
value = "$notification_servicedisplayname$"
vars += {
notification_servicename = "$service.name$"
notification_serviceoutput = "$service.output$"
notification_servicestate = "$service.state$"
notification_servicedisplayname = "$service.display_name$"
object TimePeriod "24x7" {
import "legacy-timeperiod"
display_name = "Icinga 2 24x7 TimePeriod"
ranges = {
"monday" = "00:00-24:00"
"tuesday" = "00:00-24:00"
"wednesday" = "00:00-24:00"
"thursday" = "00:00-24:00"
"friday" = "00:00-24:00"
"saturday" = "00:00-24:00"
"sunday" = "00:00-24:00"
and the first configured hosts looks like that:
object Host "wks-test" {
/* Import the default host template defined in `templates.conf`. */
import "generic-host"
vars.client_endpoint = name
/* Specify the address attributes for checks e.g. `ssh` or `http`. */
address = "XXX"
address6 = "::1"
/* Set custom attribute `os` for hostgroup assignment in `groups.conf`. */
vars.os = "Linux"
vars.disks["disk /"] = {
disk_partitions = "/"
/* Define notification mail attributes for notification apply rules in `notifications.conf`. */
vars.notification["mail"] = {
/* The UserGroup `icingaadmins` is defined in `users.conf`. */
object Endpoint "wks-test" {
host = "wks-test"
object Zone "wks-test" {
endpoints = [ "wks-test" ]
parent = "master"
