I have configured both the Monitoring module and the IcingaDB Web module on one of our Icinga master servers.
I noticed a difference in how sensitive custom variables are displayed:
In the Monitoring module / tactical view, credentials stored under custom variables are hidden or masked correctly.
In the IcingaDB Web module, the same credentials are visible in plain text under the variables section.
This creates a security concern, because users who can access IcingaDB Web are able to see sensitive values directly.
I would like to understand:
Is this expected behavior in IcingaDB Web?
Is there any way to mask or hide sensitive custom variables there?
What is the recommended best practice for storing credentials securely when using IcingaDB?
Example:
A custom variable containing credentials is masked in the Monitoring module, but the same value is shown in clear text in IcingaDB Web.
Environment:
Icinga Web 2 Version: 2.12.6
Icinga 2 version (icinga2 --version): r2.15.2-1
**Icinga DB / IcingaDB Web version:**1.3.0
Operating System and version: RHEL 9
Webserver, PHP versions: PHP 8.3.29
Additional notes:
This behavior is reproducible on our side and appears to be consistent for custom variables containing credentials.
Any clarification or recommendation would be appreciated.
