Is it possible to integrate icinga2 to a third part service/tool via webhook.
I am looking for a way to get notified for alerts generated from icinga2 to my tool instead of mail/text.
Usecase:
Alerts generated in Icinga2 → icinga2 sends notification/event to my tool
One way which I have seen in some other tools is they allow webhook integration i.e. you generate your webhook, provide that to the tool and then tool stars sending you alerts/events to your tool. But I couldnt find any such option in Icinga portal. Since I am new to Icinga2, thought of reaching out to the community for help.
I am not aware of any existing notification script, but you can for sure create your own to do this.
If the tool allows a bi-directional communication, I recommend adding an acknowledgement containing a link, ticket number or similar after the notification so you also have the state in Icinga.
If you can write a script to do what you want, Icinga can be setup to call it with arguments you configure.
Edit: There are several repos on NETWAYS’ github with notification examples. The telegram seems the most thoroughly documented if you’re looking for an example:
