I am new to the the Icinga2 world. I am trying to send message into Icinga2 by way of REST API. Is there away or an example of sending message in via POSTMAN that someone as already done?
Is there a complete list of API endpoints for Icinga2 / Director? I see the usage for adding host, but what about adding messages?
Thank you for your response. Please excuse me for my use of vocabulary regarding Icinga2, for I am new to the platform. I am more so familiar with HP Openview productions, so I am trying to understand things in a 1:1 relationship.
What I am looking to get clarity on is can I for instance, use something like “Postman,” to create a “POST,” method with a specif payload to post a message or an alarm into Icinga2’s dashboard to where a user can open and read the complete message instance and acknowledge when done as normal. I am looking at an option to use xMatters to push a message/alerts/alarms into Icinga2.
Now, did note the “add-comment,” endpoint which is kinda what I am looking for, but I noticed that this effort is added to a service. One of the difficulties I am facing is that I am trying to evaluate Icinga2 as how to monitor a “Server-less,” infrastructure where there is no place to deploy an agent, or monitor a static IP Address. I just need to present a currently status of an application.
Secondly, is there a complete list of REST API for Icinga Director?
i think what you want is process-check-result or as we also say passive service. With a passive service you can send the check result via api to icinga and set it OK/WARNING/CRITICAL with a check result output (text) that you want to send.
