Seesion Timeout in Icingaweb2 Portal
Hi. Currently i have configured the session timeout for the icingaweb2 portal, but its not working.
Below is the procedure configured for the session expire
  1. Open /etc/php.ini
  2. Change the session.gc_maxlifetime value to 30 seconds
i have set the value to 30 seconds but the session is not timeout
Kindly help whether any other configuration need to changed/updated for session timeout ( icingaweb2 portal)
Icinga2 version
Copyright © 2012-2019 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-1062.1.2.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.5
Build host: afcad697467e
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
Icingaweb2 uses php-fpm on CentOS, so you need to edit the php.ini from php-fpm.
You should find the ini files under /etc/opt/rh/rh-php71/, and dont forget to restart the php-fpm daemon after changing those ini files.
