I am currently using icinga 2.14.5 with icingadb 1.3 and icinga web 2.12.4.
I am looking into a way to store a secret variable (like a password) for a host, so it can be used in a service check.
Does icinga have a good solution for this?
Hi @nicolasberens,
That depends on what your requirements are. Just the storage of such a thing in general or would you like to handle that different than other variables?
i would like to handle it different to other variables, mainly because every var is shown to every user in the webinterface. (and the check command too).
A way to mask these would be a good start
@nicolasberens be careful, where in your config you put the password as it could easily end up on every host with an Icinga2 agent!
In icingaweb2 i advice you to restrict the Users who can see Custom Variables and you also should check in the roles icingadb /protect/variables.
