I see these errors on the secondary master in the icigna2.log. This is on v2.5.4
critical/SSL: Could not open CA key file '/var/lib/icinga2/ca/ca.key': 33558530, "error:02001002:system library:fopen:No such file or directory"
critical/SSL: Error on bio X509 AUX reading pem file '/var/lib/icinga2/ca/ca.crt': 33558530, "error:02001002:system library:fopen:No such file or directory"
AFAIK, the CA directory should only exist on the config master. The ca.key currently in /etc/icinga2/pki on the secondary. So I don’t understand why we see these errors on it.
Please advise,
