I’m trying to understand these 2 processes which are interleaved with each other. I’ve been seeing this problem where checks stay into “UNKNOWN” state for > 10minutes after a config change is made on the Icinga master. As per my understanding, a config change will reload the Icinga2 process on the masters and then on the satellites. Waiting for that long is a bit making people paranoid so I’m trying to find a way to speed up this or at least find what is causing this at the first place.
Does one small config change make full config sync across the cluster or just the delta?
Probably after the reload, the load balancing occurs on the satellites. Am I right?
Do satellite try to load balance from the scratch ( full config sync) or only deal with delta coming off the config sync?
Hi @monigacom,
I fear I can not provide you with accurate knowledge on the topic, but would like to help.
I think, the configuration is synced in full everytime, although mostly this is a negligible amount of time in the grand scheme of things.
The config reload though, which involves compiling the config first probably takes far longer than that (much much longer depending on how the config was designed).
Now something might be off with your setup, I can not really tell without seeing it, but it might also be completely fine.
What is the Check Period on those checks?
Hi, sorry for the delay. Maybe the checks are schedule to execute some time after the program start to avoid executing all of them at once (which could cause other problems).
Are there a lot of checks on that machine (which would imply that queue might be quite long and the checks therefore delayed)?
It’s not just one host but multiple hosts actually. I suspect it may be related to MaxConcurrentChecks but I don’t know how to confirm that’s the case. Enabling debuglog doesn’t provide any information in this regard.
Are there a lot of checks being executed on that node?
The default (512) is high enough for most environments.
You can modify that to a higher number of course.
