Hello everyone,
I’ve been trying for a few days to have my satellite run real checks other than ping. But the checks get stuck in the status pending. A synchronization between master and satellite works. Pings are performed from the satellite. It’s strange that a check shows a check source that doesn’t exist in the configurations. This is my test environment. I only set up the director for testing, but it is not really used. Thanks for the help in advance.
Best regards
Rico
here my configuration:
Both (master and satellite) has version: r2.13.3-1
Both Ubuntu 20.04
on master:
icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf icingadb influxdb influxdb2 livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command graphite ido-mysql ido-pgsql mainlog notification
on satellite:
Disabled features: command compatlog debuglog elasticsearch gelf graphite icingadb influxdb influxdb2 livestatus notification opentsdb perfdata statusdata syslog
Enabled features: api checker mainlog
my zones.conf on master
* on 2022-03-08 14:36:22 +0100
object Endpoint "esn-svm037" {
object Endpoint "nbb-vm-013" {
object Zone "master" {
endpoints = [ "esn-svm037" ]
global = true
global = true
object Zone "nbb-vm-013" {
endpoints = [ "nbb-vm-013" ]
parent = "master"
zones.conf on satellite
* on 2022-05-09 07:54:59 +0200
host = "10.88.183.37"
port = "5665"
parent = "master"
global = true
global = true
the Endpointlist on satellite
icinga2 object list --type Endpoint
Object 'esn-svm037' of type 'Endpoint':
% declared in '/etc/icinga2/zones.conf', lines 6:1-6:28
* __name = "esn-svm037"
* host = ""
* log_duration = 86400
* name = "esn-svm037"
* package = "_etc"
* port = "5665"
* source_location
* first_column = 1
* first_line = 6
* last_column = 28
* last_line = 6
* path = "/etc/icinga2/zones.conf"
* templates = [ "esn-svm037" ]
% = modified in '/etc/icinga2/zones.conf', lines 6:1-6:28
* type = "Endpoint"
* zone = ""
Object 'nbb-vm-013' of type 'Endpoint':
% declared in '/etc/icinga2/zones.conf', lines 9:1-9:28
* __name = "nbb-vm-013"
* host = ""
* name = "nbb-vm-013"
* package = "_etc"
* port = "5665"
* source_location
* first_column = 1
* first_line = 9
* last_column = 28
* last_line = 9
* templates = [ "nbb-vm-013" ]
% = modified in '/etc/icinga2/zones.conf', lines 9:1-9:28
* type = "Endpoint"
* zone = ""
on master
icinga2 object list --type Zone
Object 'nbb-vm-013' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 18:1-18:24
* endpoints = [ "nbb-vm-013" ]
% = modified in '/etc/icinga2/zones.conf', lines 19:2-19:29
* global = false
* package = "_etc"
* parent = "master"
% = modified in '/etc/icinga2/zones.conf', lines 20:2-20:18
* source_location
* first_column = 1
* first_line = 18
* last_column = 24
* last_line = 18
% = modified in '/etc/icinga2/zones.conf', lines 18:1-18:24
* type = "Zone"
* zone = ""
Object 'master' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 14:1-14:20
* __name = "master"
* endpoints = [ "esn-svm037" ]
% = modified in '/etc/icinga2/zones.conf', lines 15:9-15:36
* global = false
* name = "master"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 14
* last_column = 20
* last_line = 14
* templates = [ "master" ]
% = modified in '/etc/icinga2/zones.conf', lines 14:1-14:20
* type = "Zone"
* zone = ""
Object 'global-templates' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 23:1-23:30
* __name = "global-templates"
* endpoints = null
* global = true
% = modified in '/etc/icinga2/zones.conf', lines 24:2-24:14
* name = "global-templates"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 23
* last_column = 30
* last_line = 23
* templates = [ "global-templates" ]
% = modified in '/etc/icinga2/zones.conf', lines 23:1-23:30
* type = "Zone"
* zone = ""
Object 'director-global' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 27:1-27:29
* __name = "director-global"
* endpoints = null
* global = true
% = modified in '/etc/icinga2/zones.conf', lines 28:2-28:14
* name = "director-global"
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 27
* last_column = 29
* last_line = 27
* templates = [ "director-global" ]
% = modified in '/etc/icinga2/zones.conf', lines 27:1-27:29
* type = "Zone"
* zone = ""
this works on satellite
object Host "imos_mc1_nbb" {
import "generic-host"
address = "imos1.multiconnect.de"
vars.agent_endpoint = "nbb-vm-013"
vars.location = "nb"
object Host "imos_mc2_nbb" {
address = "imos2.multiconnect.de"
This not
object Host "nbb-vm-73-019" {
import "generic-linux"
address = "10.120.73.19"
vars.os = "Linux"
vars.department = "tools"
vars.procs_linux = true
vars.hostgroup = "yatu"
apply Service "mem-sat" {
import "generic-service"
check_command = "nrpe"
vars.nrpe_command = "check_memory"
vars.nrpe_arguments = [ "-w $mem_warning$ -c $mem_critical$" ]
assign where host.vars.os == "Linux" && host.vars.agent_endpoint
ignore where host.address == "127.0.0.1"
there is no checksource notified
here is completely wrong check source inside but the right agent_endpoint
