i have a satellite that could reach the master, another satellit wouldn’t be able to connect to master but to that satellite. Now … that satellite1 should be master and client, but I don’t know how to configure.
the connection satellite1 <-> master is successful, node is listed and everything looks fine.
But then on the satellite2 i want to do the node wizard:
Please specify the request ticket generated on your Icinga 2 master (optional).
(Hint: # icinga2 pki ticket --cn ‘satellite2’): 8ba08788e7ce3d8bf8fa8a328ba53f895f02209c
critical/cli: Could not fetch valid response. Please check the master log.
critical/cli: Failed to fetch signed certificate from master ‘192.168.250.1, 5665’. Please try again.
and on the satellite1:
[2021-02-19 09:47:31 +0100] information/ApiListener: New client connection for identity ‘satellite2’ from [192.168.250.2]:41402 (certificate validation failed: code 18: self signed certificate)
[2021-02-19 09:47:41 +0100] warning/ApiListener: No data received on new API connection for identity ‘satellite2’. Ensure that the remote endpoints are properly configured in a cluster setup.
So far, the ca list on satellite1 is empty so he couldnt create a certificate, but if I configure that as master, my node setup as client to master is missing or where is my mistake…
happy on any hint
Version used (
icinga2 --version) r2.10.3-1 -
Operating System and version debian10
Enabled features (
icinga2 feature list) api checker mainlog -
Icinga Web 2 version and modules (System - About)
Config validation (
icinga2 daemon -C) good -
If you run multiple Icinga 2 instances, the
zones.conffile (oricinga2 object list --type Endpointandicinga2 object list --type Zone) from all affected nodesObject ‘masterfqdn’ of type ‘Endpoint’:
% declared in ‘/etc/icinga2/zones.conf’, lines 6:1-6:67- __name = “masterfqdn”
- host = “masterfqdn”
% = modified in ‘/etc/icinga2/zones.conf’, lines 7:2-7:59 - log_duration = 86400
- name = “masterfqdn”
- package = “_etc”
- port = “5665”
% = modified in ‘/etc/icinga2/zones.conf’, lines 8:2-8:14 - source_location
- first_column = 1
- first_line = 6
- last_column = 67
- last_line = 6
- path = “/etc/icinga2/zones.conf”
- templates = [ “masterfqdn” ]
% = modified in ‘/etc/icinga2/zones.conf’, lines 6:1-6:67 - type = “Endpoint”
- zone = “”
Object ‘satellite1’ of type ‘Endpoint’:
% declared in ‘/etc/icinga2/zones.conf’, lines 15:1-15:31
- __name = “satellite1”
- host = “”
- name = “satellite1”
- package = “_etc”
- port = “5665”
- source_location
- first_column = 1
- first_line = 15
- last_column = 31
- last_line = 15
- templates = [ “satellite1” ]
% = modified in ‘/etc/icinga2/zones.conf’, lines 15:1-15:31 - type = “Endpoint”
- zone = “”
Object ‘satellite2’ of type ‘Endpoint’:
% declared in ‘/etc/icinga2/zones.conf’, lines 31:1-31:31
- __name = “satellite2”
- host = “”
- name = “satellite2”
- package = “_etc”
- port = “5665”
- source_location
- first_column = 1
- first_line = 31
- last_column = 31
- last_line = 31
- templates = [ “satellite2” ]
% = modified in ‘/etc/icinga2/zones.conf’, lines 31:1-31:31 - type = “Endpoint”
- zone = “”
