Roll out Icinga2 agents with ansible and Icinga Director
actually i am trying to roll out my icinga2 agents with ansible.
I got a fresh install of latest Icinga2 and Icinga Director.
Already i imported the agent hosts from ldap to the director and could deploy from director to icinga2.
Here are the ansible tasks (after apt installation) for the agent hosts:
# Register the client
- name: Get the install-key
  ansible.builtin.shell: icinga2 pki ticket --cn "{{ inventory_hostname }}"
  register: ticket
  become: true
  delegate_to: icinga2.domain.de
- name: Create host certs
  command: >
    icinga2 pki new-cert
      --key /var/lib/icinga2/certs/"{{ inventory_hostname }}".key
      --cert /var/lib/icinga2/certs/"{{ inventory_hostname }}".crt
  become: true
- name: Retrieve trusted cert from parent host
  command: >
    icinga2 pki save-cert
      --host icinga2.domain.de
      --key "{{ inventory_hostname }}".key
      --cert "{{ inventory_hostname }}".crt
      --trustedcert /var/lib/icinga2/certs/icinga2.domain.de.crt
  become: true
- name: Register the Icinga2 client
  command: >
    icinga2 node setup
      --zone "{{ inventory_hostname }}"
      --endpoint icinga2.domain.de
      --parent_host icinga2.domain.de
      --parent_zone master
      --ticket "{{ticket.stdout}}"
      --accept-commands
      --accept-config
      --disable-confd
  become: true
- name: Restart service Icinga2
  ansible.builtin.systemd:
    state: restarted
    daemon_reload: yes
  become: true
The installation of the agents works fine so far, the playbook is running without problems.
At next i created a simple apt_check service, but i get the following error while deploying it:
[2022-11-30 21:46:45 +0100] information/cli: Icinga application loader (version: r2.13.6-1)
[2022-11-30 21:46:45 +0100] information/cli: Loading configuration file(s).
[2022-11-30 21:46:45 +0100] warning/config: Ignoring directory '/var/lib/icinga2/api/zones/icinga2.domain.de' for unknown zone 'icinga2.domain.de'.
[2022-11-30 21:46:45 +0100] information/ConfigItem: Committing config item(s).
[2022-11-30 21:46:45 +0100] information/ApiListener: My API identity: icinga2.domain.de
[2022-11-30 21:46:45 +0100] critical/config: Error: Validation failed for object 'docker01.domain.de!apply_check_apt' of type 'Service'; Attribute 'command_endpoint': Object 'docker01.domain.de' of type 'Endpoint' does not exist.
Location: in [stage]/zones.d/director-global/service_templates.conf: 3:5-3:32
[stage]/zones.d/director-global/service_templates.conf(1): template Service "template_check_apt" {
[stage]/zones.d/director-global/service_templates.conf(2):     check_command = "apt"
[stage]/zones.d/director-global/service_templates.conf(3):     command_endpoint = host_name
[stage]/zones.d/director-global/service_templates.conf(4): }
[stage]/zones.d/director-global/service_templates.conf(5):
The config check seems fine:
root@docker01:/etc/icinga2# icinga2 daemon -C
[2022-11-30 21:48:25 +0100] information/cli: Icinga application loader (version: r2.13.6-1)
[2022-11-30 21:48:25 +0100] information/cli: Loading configuration file(s).
[2022-11-30 21:48:25 +0100] information/ConfigItem: Committing config item(s).
[2022-11-30 21:48:25 +0100] information/ApiListener: My API identity: docker01.domain.de
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 4 Zones.
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 2 Endpoints.
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2022-11-30 21:48:25 +0100] information/ConfigItem: Instantiated 244 CheckCommands.
[2022-11-30 21:48:25 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2022-11-30 21:48:25 +0100] information/cli: Finished validating the configuration file(s).
service-template:
service apply rule:
zones.d/director-global/service_apply.conf
apply Service "apply_check_apt" {
    import "template_check_apt"
    assign where match("*ebian*", host.vars.host_os)
Can you help me to get this running?
Thanks in advance,
Alex
Blind guess, you did not set Icinga Agent to yes for that host object in the director.
Thanks for your reply.
It happens just when I set it to the agent.
I also use Ansible to manage the Icinga2 Agent and use the Director.
This are the settings on one such hosts.
Maybe you have some clutter in your config files. Run following commands to get a clean config:
systemctl stop icinga2
rm -rf /var/lib/icinga2/api/{packages,zones,zones-stage}/*
systemctl start icinga2
and deploy within director again.
Thank you, thats it!
