Rocket.Chat notification help
Hello again,
I want to send info notification to a rocket.chat channel.
I’ve followed the official guide, but I don’t get it to work.
I use the icinga2 Director module to create the commands, one thing is diffrent in my configuration - I don’t know how to create the env = { ... variable as seen in github.
My command configuration:
zones.d/director-global/commands.conf
object NotificationCommand "rocketchat" {
    import "plugin-notification-command"
    command = [ "/etc/icinga2/scripts/notify_rocketchat" ]
    arguments += {
        "-host.action_url" = "$rocketchat_host_action_url$"
        "-host.display_name" = "$host.display_name$"
        "-host.name" = "$host.name$"
        "-host.output" = "$host.output$"
        "-host.state" = "$host.state$"
        "-icinga.timet" = "$icinga.timet$"
        "-service.action_url" = "$rocketchat_service_action_url$"
        "-service.display_name" = "$service.display_name$"
        "-service.name" = "$service.name$"
        "-service.output" = "$service.output$"
        "-service.state" = "$service.state$"
    vars.rocketchat_host_action_url = "$host.action_url$"
    vars.rocketchat_service_action_url = "$service.action_url$"
My notification template looks like this:
zones.d/s060w44/notification_templates.conf
template Notification "rocketchat-notifiy-template" {
    command = "rocketchat"
    states = [ Critical, OK ]
    types = [ Acknowledgement, Problem, Recovery ]
    users = [ "rocket.chat" ]
.. and both notification commands look like this:
zones.d/s060w44/notification_apply.conf
apply Notification "host rocketchat" to Host {
    import "rocketchat-notifiy-template"
    assign where match("*", host.name)
    states = [ Down, Up ]
    types = [ Acknowledgement, Custom, Problem, Recovery ]
    vars.rocketchat_host_action_url = "https://URL/hooks/6xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
    vars.rocketchat_service_action_url = "https://URL/hooks/6xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
apply Notification "service rocketchat" to Service {
Thanks for any help!
change the command in commands.conf to:
/usr/bin/env ROCKETCHAT_WEBHOOK_URL="https://test/hook" /etc/icinga2/scripts/notify_rocketchat
I tested it out with:
/usr/bin/env ROCKETCHAT_WEBHOOK_URL="https://test/hook" printenv
Hello, how/where do I do this in icinga2 director?
first picture:
replace
with:
Hello, I’ve past the string (/usr/bin/env ROCKETCHAT_WEBHOOK_URL=“https://url” /etc/icinga2/scripts/notify_rocketchat) in the command field.
    command = [
        "/usr/bin/env",
        "ROCKETCHAT_WEBHOOK_URL=\"https://url\"",
    arguments += {
I don’t think the director acknowledge that /usr/bin/env ROCKETCHAT_WEBHOOK_URL= is 1 command because it sets a comma. Or did I do something wrong?
looks fine to me,
my test command renderd to
object CheckCommand "envtest" {
    import "plugin-check-command"
    command = [
        "/usr/bin/env",
        "ROCKETCHAT_WEBHOOK_URL=\"https://test/hook\"",
        "printenv"
and produced the following output:
PIDFILE=/run/icinga2/icinga2.pid
PWD=/
LANG=en_US.UTF-8
INVOCATION_ID=148ff0e1959d42f281ddf932ead25000
SHLVL=0
ICINGA2_ERROR_LOG=/var/log/icinga2/error.log
JOURNAL_STREAM=9:34313
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
LC_NUMERIC=C
Okay, right now I get no messages, how can I test run it like you did?
try to run the go command manually (from shell) first, so we can exclude any configuration issues on the rocketchat side
Did you mean this?
root@Server:/etc/icinga2/scripts# /etc/icinga2/scripts/notify_rocketchat
$ROCKETCHAT_WEBHOOK_URL missing
yes but your command is incomplete:
  1. read the documentation on notify_rocketchat
  2. set the environmentvar of the url via export
  3. prepare the shell command
  4. run it and see if that works and connects to your rocketchat instance
Hello, I think I do someting wrong with setting a variable as shown in the documentation.
root@s060w44:~# /etc/icinga2/scripts/notify_rocketchat env={"ROCKETCHAT_WEBHOOK_URL" = "https://URL"}
root@s060w44:~# /etc/icinga2/scripts/notify_rocketchat vars.rocketchat_webhook_url="https://URL"
root@s060w44:~#
But I can run a curl command to the rocket.chat webhook, so connection should not be a problem.
please look up who to set an environment variable in bash.
ROCKETCHAT_WEBHOOK_URL is an environment variable
https://www.google.com/search?q=set+environment+var+in+bash&oq=set+environment+var+in+bash
Hello, communication works:
/etc/icinga2/scripts/notify_rocketchat -host.name hostname -host.state down -host.name hostname -service.name ping -service.state up
Result:
well thats great,
please try if that works and replace the webhook url:
/usr/bin/env ROCKETCHAT_WEBHOOK_URL="https://test/hook" /etc/icinga2/scripts/notify_rocketchat -host.name hostname -host.state down -host.name hostname -service.name ping -service.state up
Yes, this works aswell!
if you look up a service or a host in icingaweb, what do you see under the section Notifications?
looks great so the service sends notifications
look into the icigna2.log and search for notification
Hello, this is the output.
[2022-07-28 10:59:37 +0000] debug/HttpUtility: Request body: '{"author":"Username","comment":"test","force":false,"host":"test"}'
[2022-07-28 10:59:37 +0000] information/Notification: Completed sending 'Custom' notification 'test!host rocketchat' for checkable 'test' and user 'rocket.chat' using command 'rocketchat_alt'.
[2022-07-28 10:59:37 +0000] notice/Process: PID 1242560 ('/usr/bin/env' 'ROCKETCHAT_WEBHOOK_URL="https://URL/hooks/"' '/etc/icinga2/scripts/notify_rocketchat' '-host.action_url' 'https://URL/hooks/' '-host.display_name' 'test' '-host.name' 'test' '-host.output' 'PING CRITICAL - Packet loss = 100%' '-host.state' 'DOWN' '-icinga.timet' '1659005977' '-service.action_url' 'https://URL/hooks/') terminated with exit code 2
[2022-07-28 10:59:37 +0000] warning/PluginNotificationTask: Notification command for object 'test' (PID: 1242560, arguments: '/usr/bin/env' 'ROCKETCHAT_WEBHOOK_URL="https://URL/hooks/"' '/etc/icinga2/scripts/notify_rocketchat' '-host.action_url' 'https://URL/hooks/' '-host.display_name' 'test' '-host.name' 'test' '-host.output' 'PING CRITICAL - Packet loss = 100%' '-host.state' 'DOWN' '-icinga.timet' '1659005977' '-service.action_url' 'https://URL/hooks/') terminated with exit code 2, output: -service.* is given, missing some of: -host.name, -service.name, -service.state
your host notification is not working because the service action url is set
remove from Notification "host rocketchat" to Host
