Retry check doesn't work as expected
Icinga conf:
template Service "my_passive_service" {
    import "base_template"
    check_command = "passive"
    max_check_attempts = "5"
    check_interval = 90s
    retry_interval = 90s
    check_timeout = 10s
    command_endpoint = host.name
apply Service "my_service" {
  import "my_passive_service"
  assign where regex("*xxx*", host.name)
Icinga web behavior seems a little bit strange, since switching from one to another state level can overlap as shown in figure:
It looks like a bug in icinga2. Why is that happend and how to fix it?
Additional information about our icinga2 installation:
icinga2 --version
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Debian GNU/Linux
  Platform version: 9 (stretch)
  Kernel: Linux
  Kernel version: 4.19.0-0.bpo.1-amd64
  Architecture: x86_64
Build information:
  Compiler: GNU 6.3.0
  Build host: cb654124b660
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
