Hi
When using Icinga web2 and the monitoring module, you can restrict access to custom Variables as described here: Restrict Custom Variables - Icinga Web
Can you define similar restrictions when using the icingadb module and disabling the monitoring module? I don’t find anything similar in the web gui.
Kind regards
Matthias
it is in the role setup now:
Thanks a lot, I did not see the other post, sorry.
