i try to update the Default page size from 25 to 500 and i have the error message
Fatal error
: Uncaught ErrorException: Uncaught LogicException: Please check if a db instance exists at all in /usr/share/php/Icinga/Common/Database.php:28 Stack trace: #0 /usr/share/php/Icinga/Application/ProvidedHook/DbMigration.php(21): Icinga\Application\ProvidedHook\DbMigration->getWebDb() #1 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(293): Icinga\Application\ProvidedHook\DbMigration->getDb() #2 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(172): Icinga\Application\Hook\DbMigrationHook->load() #3 /usr/share/php/Icinga/Application/MigrationManager.php(306): Icinga\Application\Hook\DbMigrationHook->getMigrations() #4 /usr/share/php/Icinga/Application/MigrationManager.php(56): Icinga\Application\MigrationManager->load() #5 /usr/share/php/Icinga/Application/MigrationManager.php(106): Icinga\Application\MigrationManager->getPendingMigrations() #6 /usr/share/php/Icinga/Application/MigrationManager.php(69): Icinga\Application\MigrationManager->count() #7 /usr/share/php/Icinga/Application/MigrationManager.php(74): Icinga\Application\MigrationManager->hasPendingMigrations() #8 /usr/share/icingaweb2/application/controllers/ErrorController.php(99): Icinga\Application\MigrationManager->hasMigrations() #9 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Action.php(516): Icinga\Controllers\ErrorController->errorAction() #10 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch() #11 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(954): Icinga\Web\Controller\Dispatcher->dispatch() #12 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #13 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #14 /usr/share/icingaweb2/public/index.php(4): require_once(‘…’) #15 {main} Next Zend_Controller_Exception: Please check if a db instance exists at all#0 /usr/share/php/Icinga/Application/ProvidedHook/DbMigration.php(21): Icinga\Application\ProvidedHook\DbMigration->getWebDb() #1 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(293): Icinga\Application\ProvidedHook\DbMigration->getDb() #2 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(172): Icinga\Application\Hook\DbMigrationHook->load() #3 /usr/share/php/Icinga/Application/MigrationManager.php(306): Icinga\Application\Hook\DbMigrationHook->getMigrations() #4 /usr/share/php/Icinga/Application/MigrationManager.php(56): Icinga\Application\MigrationManager->load() #5 /usr/share/php/Icinga/Application/MigrationManager.php(106): Icinga\Application\MigrationManager->getPendingMigrations() #6 /usr/share/php/Icinga/Application/MigrationManager.php(69): Icinga\Application\MigrationManager->count() #7 /usr/share/php/Icinga/Application/MigrationManager.php(74): Icinga\Application\MigrationManager->hasPendingMigrations() #8 /usr/share/icingaweb2/application/controllers/ErrorController.php(99): Icinga\Application\MigrationManager->hasMigrations() #9 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Action.php(516): Icinga\Controllers\ErrorController->errorAction() #10 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch() #11 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(954): Icinga\Web\Controller\Dispatcher->dispatch() #12 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #13 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #14 /usr/share/icingaweb2/public/index.php(4): require_once(‘…’) #15 {main} in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Plugin/Broker.php:335 Stack trace: #0 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(965): Zend_Controller_Plugin_Broker->postDispatch() #1 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #2 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #3 /usr/share/icingaweb2/public/index.php(4): require_once(‘…’) #4 {main} thrown in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Plugin/Broker.php:335 Stack trace: #0 [internal function]: Icinga\Application\Web->Icinga\Application{closure}() #1 {main} Next Zend_Controller_Exception: Uncaught LogicException: Please check if a db instance exists at all in /usr/share/php/Icinga/Common/Database.php:28 Stack trace: #0 /usr/share/php/Icinga/Application/ProvidedHook/DbMigration.php(21): Icinga\Application\ProvidedHook\DbMigration->getWebDb() #1 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(293): Icinga\Application\ProvidedHook\DbMigration->getDb() #2 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(172): Icinga\Application\Hook\DbMigrationHook->load() #3 /usr/share/php/Icinga/Application/MigrationManager.php(306): Icinga\Application\Hook\DbMigrationHook->getMigrations() #4 /usr/share/php/Icinga/Application/MigrationManager.php(56): Icinga\Application\MigrationManager->load() #5 /usr/share/php/Icinga/Application/MigrationManager.php(106): Icinga\Application\MigrationManager->getPendingMigrations() #6 /usr/share/php/Icinga/Application/MigrationManager.php(69): Icinga\Application\MigrationManager->count() #7 /usr/share/php/Icinga/Application/MigrationManager.php(74): Icinga\Application\MigrationManager->hasPendingMigrations() #8 /usr/share/icingaweb2/application/controllers/ErrorController.php(99): Icinga\Application\MigrationManager->hasMigrations() #9 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Action.php(516): Icinga\Controllers\ErrorController->errorAction() #10 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch() #11 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(954): Icinga\Web\Controller\Dispatcher->dispatch() #12 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #13 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #14 /usr/share/icingaweb2/public/index.php(4): require_once(‘…’) #15 {main} Next Zend_Controller_Exception: Please check if a db instance exists at all#0 /usr/share/php/Icinga/Application/ProvidedHook/DbMigration.php(21): Icinga\Application\ProvidedHook\DbMigration->getWebDb() #1 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(293): Icinga\Application\ProvidedHook\DbMigration->getDb() #2 /usr/share/php/Icinga/Application/Hook/DbMigrationHook.php(172): Icinga\Application\Hook\DbMigrationHook->load() #3 /usr/share/php/Icinga/Application/MigrationManager.php(306): Icinga\Application\Hook\DbMigrationHook->getMigrations() #4 /usr/share/php/Icinga/Application/MigrationManager.php(56): Icinga\Application\MigrationManager->load() #5 /usr/share/php/Icinga/Application/MigrationManager.php(106): Icinga\Application\MigrationManager->getPendingMigrations() #6 /usr/share/php/Icinga/Application/MigrationManager.php(69): Icinga\Application\MigrationManager->count() #7 /usr/share/php/Icinga/Application/MigrationManager.php(74): Icinga\Application\MigrationManager->hasPendingMigrations() #8 /usr/share/icingaweb2/application/controllers/ErrorController.php(99): Icinga\Application\MigrationManager->hasMigrations() #9 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Action.php(516): Icinga\Controllers\ErrorController->errorAction() #10 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch() #11 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(954): Icinga\Web\Controller\Dispatcher->dispatch() #12 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #13 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #14 /usr/share/icingaweb2/public/index.php(4): require_once(‘…’) #15 {main} in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Plugin/Broker.php:335 Stack trace: #0 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(965): Zend_Controller_Plugin_Broker->postDispatch() #1 /usr/share/php/Icinga/Application/Web.php(294): Zend_Controller_Front->dispatch() #2 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #3 /usr/share/icingaweb2/public/index.php(4): require_once(‘…’) #4 {main} thrown#0 [internal function]: Icinga\Application\Web->Icinga\Application{closure}() #1 {main} in /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Plugin/Broker.php:262 Stack trace: #0 /usr/share/icinga-php/vendor/vendor/shardj/zf1-future/library/Zend/Controller/Front.php(923): Zend_Controller_Plugin_Broker->routeShutdown() #1 /usr/share/php/Icinga/Application/Web.php(461): Zend_Controller_Front->dispatch() #2 [internal function]: Icinga\Application\Web->Icinga\Application{closure}() #3 {main} thrown in
on line
262
- Icinga Web 2 Version 2.12.2 (git commit : 7f9217b0521f19f770ad59ca17d7d4b3514e54e5
- Used modules and their versions (System - About) :
doc 2.12.2
migrate 2.12.2
monitoring 2.12.2
setup 2.12.2
test 0.0.0
translation 2.12.2
icinga/icinga-php-library 0.14.1
icinga/icinga-php-thirdparty 0.12.1 - Web browser used firefox / chrome
- Icinga 2 version used (
icinga2 --version)
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.5-1)
Copyright (c) 2012-2025 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Debian GNU/Linux
Platform version: 12 (bookworm)
Kernel: Linux
Kernel version: 6.1.0-22-amd64
Architecture: x86_64
Build information:
Compiler: GNU 12.2.0
OpenSSL version: OpenSSL 3.0.15 3 Sep 2024
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- PHP version used (
php --version)
PHP 8.2.26 (cli) (built: Nov 25 2024 17:21:51) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.26, Copyright (c) Zend Technologies
with Zend OPcache v8.2.26, Copyright (c), by Zend Technologies - Server operating system and version
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
db :
[auth]
type = “db”
db = “pgsql”
host = “pg1”
port = “5437”
dbname = “auth”
username = “icingaauth”
password = “qqch”
charset = “UTF8”
use_ssl = “1”
[ido]
type = “db”
db = “pgsql”
host = “pg1”
port = “5437”
dbname = “icinga2”
username = “ido”
password = “qqch”
charset = “UTF8”
use_ssl = “1”
(db not accessble from wan)
i use postgresql and seems no code for postgresql in
thank you for your help
