I love the Reporting Module but Iām having trouble using the downloading PDF option. I though the problem was only with my laptop but I have try downloading the PDF in Reporting on five different system and I am getting the same error. Has anyone else resolved this problem?
This is also causing a problem with the drop down PDF option in the normal Icingaweb2 hosts and service overview webpages. If I disable the pdfexport module the overview pages will work again.
Icinga 2.11.2-1
Icingaweb2 2.7.3
idoreports 0.9.1
ipl 0.4.0
pdfexport 0.9.1
reacthuncle 0.6.0
reporting 0.10
Chrome 79.0.3945.88
Red Hat Enterprise 7.7
Thanks in advance for your help.
Alex
Did you install also all the requirements?
The pdf module also needs chrome/chromium, see https://github.com/Icinga/icingaweb2-module-pdfexport/blob/master/doc/02-Installation.md
Hello Carseten,
Yes, I have the pdfexport module installed and all the optional requirements installed.
pdfexport 0.9.1
Icingaweb2 2.7.3
RH-PHP71-PHP-FPM 7.1.30
Chrome 79.0.3945.88
mesa-libOSMesa 18.3.4.-5
mesa-libOSMesa-devel 18.3.4.-5
gnu-free-sans-fonts 20120503-8
ipa-gothic-fonts 003.03-5
ipa-pgothic-fonts 003.03-5
See PHP status message below
servicectl status rh-php71-php-fpm
ā rh-php71-php-fpm.service - The PHP FastCGI Process Manager
Loaded: loaded (/usr/lib/systemd/system/rh-php71-php-fpm.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2020-01-28 13:12:13 EST; 16min ago
Process: 5190 ExecReload=/bin/kill -USR2 $MAINPID (code=exited, status=0/SUCCESS)
Main PID: 26915 (php-fpm)
Status: "Processes active: 0, idle: 6, Requests: 29, slow: 0, Traffic: 0req/sec"
CGroup: /system.slice/rh-php71-php-fpm.service
āā26915 php-fpm: master process (/etc/opt/rh/rh-php71/php-fpm.conf
āā26916 php-fpm: pool www
āā26917 php-fpm: pool www
āā26918 php-fpm: pool www
āā26919 php-fpm: pool www
āā26920 php-fpm: pool www
āā27446 php-fpm: pool www
āā27560 /usr/bin/google-chrome-stable --headless --disable-gpu --no-sandbox --remote-debugging-port=0
āā27564 cat
āā27565 cat
āā27567 /opt/google/chrome/chrome --type=zygote --no-sandbox --headless --headless --enable-crash-reporter
āā27580 /opt/google/chrome/chrome --type=gpu-process --field-trial-handle=4059520132588618078,763673117136711017,131072 --no-sandbox --headless --headless --enable-crash-reporter --gpu-preferences=KAAAAAAAAAAgAAAgAAAAAAAAYAAAAAAAEAAAAAAAAAAAAAAAAAAAAAgAAAAAAAAA --use-gl=swiftshader-webgl --override-use-software-gl-for-tests --service-request-channel-token=1463149631323911949
āā27581 /opt/google/chrome/chrome --type=utility --field-trial-handle=4059520132588618078,763673117136711017,131072 --lang=en-US --service-sandbox-type=network --no-sandbox --use-gl=swiftshader-webgl --headless --enable-crash-reporter --service-request-channel-token=11208388452277422793 --shared-files=v8_context_snapshot_data:100,v8_natives_data:10
āā27586 /opt/google/chrome/chrome --type=renderer --no-sandbox --allow-pre-commit-input --remote-debugging-port=0 --use-gl=swiftshader-webgl --field-trial-handle=4059520132588618078,763673117136711017,131072 --disable-databases --disable-gpu-compositing --lang=en-US --headless --enable-crash-reporter --num-raster-threads=1 --service-request-channel-token=5492735694971916027 --renderer-client-id=3 --shared-files=v8_context_snapshot_data:100,v8_natives_data:10
āā27591 /opt/google/chrome/chrome --type=renderer --no-sandbox --allow-pre-commit-input --remote-debugging-port=0 --use-gl=swiftshader-webgl --field-trial-handle=4059520132588618078,763673117136711017,131072 --disable-databases --disable-gpu-compositing --lang=en-US --headless --enable-crash-reporter --num-raster-threads=1 --service-request-channel-token=4719066026970916391 --renderer-client-id=5 --shared-files=v8_context_snapshot_data:100,v8_natives_data:10
Jan 28 13:12:13 myserver systemd[1]: Starting The PHP FastCGI Process Manager...
Jan 28 13:12:13 myserver systemd[1]: Started The PHP FastCGI Process Manager.
Jan 28 13:19:41 myserver icingaweb2[27446]: WebSocket\ConnectionException in /usr/share/icingaweb2/modules/pdfexport/vendor/textalk/websocket/lib/Base.php:202 with message: Empty read; connection dead? Stream state: {"timed_out":false,"blocked":true,"eof":true,"stream_type":"tcp_socket\/ssl","mode":"r+","unread_bytes":0,"seekable":false} #0 /usr/share/icingaweb2/modules/pdfexport/vendor/textalk/websocket/lib/Base.php(92): WebSocket\Base->read(Integer) #1 /usr/share/icingaweb2/modules/pdfexport/vendor/textalk/websocket/lib/Base.php(173): WebSocket\Base->receive() #2 /usr/share/icingaweb2/modules/pdfexport/library/Pdfexport/HeadlessChrome.php(276): WebSocket\Base->close() #3 /usr/share/icingaweb2/modules/pdfexport/library/Pdfexport/HeadlessChrome.php(215): Icinga\Module\Pdfexport\HeadlessChrome->printToPDF(String, String, Array) #4 /usr/share/icingaweb2/modules/reactbundle/vendor/evenement/evenement/src/Evenement/EventEmitterTrait.php(34): Icinga\Module\Pdfexport\HeadlessChrome->Icinga\Module\Pdfexport\{closure}(String) #5 /usr/share/icingaweb2/modules/reactbundle/vendor/evenement/evenement/src/Evenement/EventEmitterTrait.php(70): Evenement\EventEmitter->Evenement\{closure}(String) #6 /usr/share/icingaweb2/modules/reactbundle/vendor/react/stream/src/ReadableResourceStream.php(146): Evenement\EventEmitter->emit(String, Array) #7 /usr/share/icingaweb2/modules/reactbundle/vendor/react/event-loop/src/StreamSelectLoop.php(244): React\Stream\ReadableResourceStream->handleData(Resource) #8 /usr/share/icingaweb2/modules/reactbundle/vendor/react/event-loop/src/StreamSelectLoop.php(211): React\EventLoop\StreamSelectLoop->waitForStreamActivity(NULL) #9 /usr/share/icingaweb2/modules/pdfexport/library/Pdfexport/HeadlessChrome.php(225): React\EventLoop\StreamSelectLoop->run() #10 /usr/share/icingaweb2/modules/pdfexport/library/Pdfexport/ProvidedHook/Pdfexport.php(82): Icinga\Module\Pdfexport\HeadlessChrome->toPdf() #11 /usr/share/icingaweb2/modules/reporting/application/controllers/ReportController.php(118): Icinga\Module\Pdfexport\ProvidedHook\Pdfexport->streamPdfFromHtml(Object(Icinga\Module\Pdfexport\PrintableHtmlDocument), String) #12 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(507): Icinga\Module\Reporting\Controllers\ReportController->downloadAction() #13 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch(String) #14 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #15 /usr/share/php/Icinga/Application/Web.php(300): Zend_Controller_Front->dispatch(Object(Icinga\Web\Request), Object(Icinga\Web\Response)) #16 /usr/share/php/Icinga/Application/webrouter.php(99): Icinga\Application\Web->dispatch() #17 /usr/share/icingaweb2/public/index.php(4): require_once(String) #18 {main}
I just found an open issue with this problem on GitHub. I will follow this and wait for a solution.
