trying to run a report i get the following error message… Can anybody point me to a solution ?
Blockquote
QLSTATE[42000]: Syntax error or access violation: 1305 FUNCTION icingadb.get_sla_ok_percent does not exist (Connection.php:401)
#0 /usr/share/icinga-php/ipl/vendor/ipl/sql/src/Connection.php(401): PDO->prepare() #1 /usr/share/icinga-php/ipl/vendor/ipl/sql/src/Connection.php(418): ipl\Sql\Connection->prepexec() #2 /usr/share/icinga-php/ipl/vendor/ipl/orm/src/Query.php(642): ipl\Sql\Connection->select() #3 /usr/share/icinga-php/ipl/vendor/ipl/orm/src/ResultSet.php(142): ipl\Orm\Query->yieldResults() #4 [internal function]: ipl\Orm\ResultSet->yieldTraversable() #5 /usr/share/icinga-php/ipl/vendor/ipl/orm/src/ResultSet.php(122): Generator->valid() #6 /usr/share/icinga-php/ipl/vendor/ipl/orm/src/ResultSet.php(114): ipl\Orm\ResultSet->advance() #7 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/ProvidedHook/Reporting/SlaReport.php(114): ipl\Orm\ResultSet->rewind() #8 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/ProvidedHook/Reporting/SlaReport.php(195): Icinga\Module\Icingadb\ProvidedHook\Reporting\SlaReport->fetchReportData() #9 /usr/share/icingaweb2/modules/icingadb/library/Icingadb/ProvidedHook/Reporting/SlaReport.php(200): Icinga\Module\Icingadb\ProvidedHook\Reporting\SlaReport->getData() #10 /usr/share/icingaweb2/modules/reporting/library/Reporting/Report.php(291): Icinga\Module\Icingadb\ProvidedHook\Reporting\SlaReport->getHtml() #11 /usr/share/icingaweb2/modules/reporting/application/controllers/ReportController.php(43): Icinga\Module\Reporting\Report->toHtml() #12 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(507): Icinga\Module\Reporting\Controllers\ReportController->indexAction() #13 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch() #14 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch() #15 /usr/share/php/Icinga/Application/Web.php(290): Zend_Controller_Front->dispatch() #16 /usr/share/php/Icinga/Application/webrouter.php(105): Icinga\Application\Web->dispatch() #17 /usr/share/icingaweb2/public/index.php(4): require_once(‘/usr/share/php/…’) #18 {main}
Blockquote
- Icinga DB Web version (System - About): 1.0.1
- Icinga Web 2 version (System - About): 2.11.1
- Web browser: Edge
- Icinga 2 version (
icinga2 --version
): r2.13.5-1 - Icinga DB version (
icingadb --version
): 1.0.0. - PHP version used (
php --version
): 7.4.3 - Server operating system and version: debian bullseye
SQL-DB: Mysql 10.5 running with galera-4
