Report Module & IDO Report Module: Delete Report with Bad Filter?
I created an SLA report and was playing around with filters trying to figure it out and ended up with a bad filter.
I can no longer load the report because of the bad filter… how can I remove it?
I figured it out.
I just copied the URL from a good report when in modify/edit mode and replaced the report ID # with the # of the bad report. This let me modify it and remove it.
It would be cool if there were a delete option in the list of reports to avoid having to do this… or maybe a filter check before it allows it to be saved or something.
Are filters documented anywhere?
Filters worknthe sane way as object filter for icingaweb roles.
Is the icingaweb2 role filtering documented somewhere? I’m searching around on my mobile but haven’t found it yet.
I’ll keep searching when I get back to a computer unless you know where it is located.
https://icinga.com/docs/icingaweb2/latest/doc/06-Security/#restrictions
Thank you! Exactly what I was looking for
