Replace / to _ string
Hi all,
Struggling to understand icinga2 script language. I have a requirement to replace / with _ for a string in a variable. I thought something like
  vars.testnew = test.replace('/' , '_')
Did you try using " instead of ’ ?
Antony.
i thought i did :). That works . Thanks - simple things .
